diyAudio Sponsor
Old 10th December 2008, 12:23 PM   #1
cjkpkg is offline cjkpkg  United States
Default Filament Xformer woes...
I bought this Xformer http://edcorusa.com/products/transfo...12_6v3a-1.html and hooked it up to the Aikido I am putting together. I am using 2 5687 tubes(12.6v) and 2 6CG7 tubes(6.3V). I am using jumper J2 only to wire the 6CG7 tubes in series.
Plugged it in last night and nothing...no glow at all. Put the DMM on it and I am getting 6.6V across the "hot" terminals and 3.1V from the CT to either of the "hot" terminals.
I am thinking that I got a bum or mis-labeled xformer no? The label says 7~9=12.6V 8CT.
I just wanted to confirm my suspicions before calling them.
I also reconfigured my phono board to parallel wiring and temporarily hooked it up to that. The filaments glowed as they should.
Old 10th December 2008, 03:32 PM   #2
Well,
I just got off the phone with the tech who actually wound my xformer. After some readings and discussion she came to the conslusion that she must have put the wrong bobbin in my unit.
They are sending me the correct unit - now thats customer service...Of course it will probably take another 3 weeks....
Oh well, I guess I have a spare 6.6V xformer for future use - she told me just to hang on to it...
Old 10th December 2008, 04:11 PM   #3
If you do not want to wait three weeks you can also set all your valves to run from 6.3V. Shouldn't be hard...and you can listen to your carols with your new Aikido
Erik
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 10th December 2008, 04:50 PM   #4
Erik
The 5687's run on 12V for the 5687 Aikido board. Not sure if there is a way to step them down...I will have to take a closer look at the board...
Old 10th December 2008, 05:27 PM   #5
Now I can understand that information on J2...
Another thing... maybe you have this sorted out, but just in case: the 5687 and the 6CG7 have different pinouts: Broskie has a special PCB for the 5687, maybe you got that one...if so, can it take the 6CG7?
Old 10th December 2008, 06:19 PM   #6
Yes, I have the unique 5687 board...This basically forces you to have a 12V power supply for V1 and V4 the way it is traced. V2 and V3 have many different options you can use and they can be either a 6V or 12V heated tube - you just use the jumpers to run V2 and V3 either in series or parallel to get the voltage you need.
I may just pick up a cheapo 12V radio shack xformer just to keep the project moving undil I get the Edcor unit. At this point I may as well use the 6V one they sent to run the heaters for the phono stage. With the 6CG7's, 5687's, and 6DJ8's using a 12V supply would run at 2.8 amps. If I use a dedicated one for the phono stage I could try different tubes like 6N1P's or something and still have pleanty of juice left over. There should be plenty of room in the chassis...
How best to use the PSU xformer I have Steerpike Tubes / Valves 1 12th November 2008 09:27 PM
Chipamp into xformer StanJ Chip Amps 10 15th May 2008 07:09 AM
Parallel vs. series filament supply - or another filament idea engels Tubes / Valves 11 13th May 2007 01:06 PM
Think these are useful -- huge xformer?! rif Parts 21 13th August 2004 10:00 PM
xformer for GC meta Chip Amps 4 4th July 2003 07:55 PM
Page generated in 0.08141 seconds (77.97% PHP - 22.03% MySQL) with 11 queries
