diyAudio Sponsor
Old 10th December 2008, 02:42 AM   #1
mach1 is offline mach1  Australia
mach1's Avatar
Default The Use of 1:1 Input Transformers in Linestages
In schematics I have often seen 1:1 input transformers employed on the inputs of linestages to provide a degree of galvanic isolation. The use of this topology is generally recommended by its proponents on sonic grounds, and several reasons have been proposed for its employment, including:
• ground loop hum rejection
• the isolation conferred on a multi-source system with multiple grounds
• common mode rejection in a noisy electromagnetic environment
• the inherent bandwidth limiting associated with transformer coupling
My question is: if you don’t have ground loop issues, employ a multi-source system, live in a noisy electromagnetic environment or require bandwidth limiting are there any sonic advantages conferred by this topology ?
My gut feeling has always been that adding extra devices to the signal chain can only detract from the overall sound, and that there would have to be a considerable influence from one or more of the factors listed above to justify their use. Opinions please
Au rutti wop-bop-a-loom-bop-a-boom-bam-boom - Richard Penniman
Old 10th December 2008, 09:45 AM   #2
SY's Avatar
It would probably confer minimal advantage in that situation. But, like me, you might be surprised at how not-quiet your quiet environment is, especially with the advent of CFL lighting.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 10th December 2008, 12:22 PM   #3
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Default Bzzz
One of the worst offenders for mains noise near audio equipment is ... ... audio equipment. It's all those capacitor input power supplies and saturating mains transformers. And you'd be amazed how difficult it is to get an active crossover system free of buzz. Input transformers can really help.
And here's the current waveform for a 9W compact fluorescent lamp...
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
OEP input transformers. Anyone used ?? Shoog Tubes / Valves 4 1st January 2008 05:24 PM
Input transformers and IC input impedances duffy Chip Amps 4 2nd December 2004 06:08 AM
Zen Linestages, X and unbalanced operation Kilentra Pass Labs 12 27th May 2003 08:24 PM
Erno Borbley preamp linestages Trax Solid State 2 5th October 2001 02:32 AM
Page generated in 0.07709 seconds (72.35% PHP - 27.65% MySQL) with 11 queries
