diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   voltage reg make heat sink live. Bad idea? (http://www.diyaudio.com/forums/tubes-valves/134560-voltage-reg-make-heat-sink-live-bad-idea.html)
phrarod 9th December 2008 04:46 PM
I'm recapping my AMC CVT3030a I saw some weird stuff around the vol reg in the ps which I can't identify. If it was a cap I would say it was leaking.
In the process I noticed apart from some thermal grease it makes contact with the heat sink which naturally makes the sink live. I've seen this in cheap ps in the past but this unit is pretty well made.
Best to leave it alone? Or isolate it with mica and a shoulder plastic washer?
DigitalJunkie 10th December 2008 01:40 AM
If the heatsink is inside the case,where you normally wouldn't be able to touch it,it's probably fine. If it's exposed-Insulate it!
phrarod 10th December 2008 01:41 AM
Its inside the case.
I wonder why designers do this? Is there some particular reason?
DigitalJunkie 10th December 2008 01:51 AM
Cost cutting?
Maybe they wanted to keep thermal resistance down?
I Dunno. :confused:
phrarod 10th December 2008 01:57 AM
Its using a run of the mill 1N5407
Copyright 1999-2017 diyAudio
