Using 2 rectifiers off 1 power supply
Hey
My geek mate says it shouldnt be done but can I hang 2 gz34 rectifiers off one heater supply? It can supply 5V at 4 amps. I realise the resistance of the heaters will be half of usual and hence the supply Voltage will be greater.. will need dropping resistors etc.
Or do I hang one off the 5v supply I have ,and one off a spare 6.3 V supply I have with the aforementioned dropping resistors
Much Appreciated
Nick
Administrator
Joined 2004
This should work just fine of off the 4A/5V winding since the filamentary load is resistive in nature. (Currents in winding will be sinusoidal and will not cause unusual heating problems.) I used to parallel 5AR4 in order to get higher current capability, particularly towards the top end of their voltage ratings.
In addition I recommend installing diodes such as UF4007 in series with each plate - you will be amazed at how many gremlins this quashes while keeping all of the advantages of tube rectification. (Things like arc over during warm up, hot flashing, etc.)
