| diyAudio Sponsor | ||
Hi
I am building a guitar amp with tube rectifier. the design only has one cap (Of filtration) before power tubes ( it has other filtration for input tube and another for screen supply). B+ Might be an issue if I use too large a resistor for an rc stage and I dont have a lot of room for a choke. The 2 dollar question is what is the smallest Resistor I can place in a CRC configuration that will have a meaningful effect? Smallest as in Value not wattage. If I put a large one in I will get too much of a drop in b+ or alternately I note Hammond make a 3 to 5 H choke that can handle up to 300mA.... I know a choke is preferable but i will have to remount power transformer All help Appreciated Thanks Nick
"Better to say nothing and keep them guessing than to speak and remove all doubt." |
#2 |
Download this and plug in numbers until you get what you want: http://www.duncanamps.com/psud2/index.html
If you measure your power transformer primary and secondary resistance, and unloaded primary and secondary voltage, and have a good estimate of the current draw for the amp, you will get very accurate results. Sheldon |
| Power Supply Module for Tube Amp | gijoe_22 | Vendor's Bazaar | 8 | 16th December 2009 02:25 PM |
| 323 A tube power supply design | pjwd | Power Supplies | 0 | 20th August 2008 08:48 AM |
| tube power supply | MiiB | Tubes / Valves | 10 | 2nd March 2008 01:52 PM |
| Tube power supply for TT | Miniwatt | Analogue Source | 1 | 8th March 2005 06:49 PM |
| Power Supply and VR tube help! | AudioGeek | Tubes / Valves | 24 | 28th February 2004 12:16 AM |
| Page generated in 0.06415 seconds (74.70% PHP - 25.30% MySQL) with 10 queries |
