| diyAudio Sponsor | ||
Does anyone know where to get transformer mounting braces like these to replace end bells? I am trying to move a transformer inside a chassis.
http://www.ecpaudio.com |
#2 |
Try 3/8" x 1/16" aluminum strip from the hardware store, a hacksaw and drill.
Don't forget to insulate them from the screws, lest you end up with a "shorted turn". You can make 50 for the price of 4 from a supplier Cheers! |
#3 | |
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#4 |
dsav,
Why not just keep the endbells? I have Mikey making me a pair of EL34 outputs which will go in Zerocase cans for the cuteness, and so I specified bracket mount. He just today posted me back saying, 'Sonofagun, the four brackets are more expensive than endbells!' I told him to nemmine, just put the endbells on there. The VT4C Tonyaba choke I want to use was real close to not fitting inside the can, so I just put a cutoff wheel on the Dremel and cut about half the 'bell' part off, 'till it was a little shy of the winding. Free brackets. Aloha, Poinz |
| toroidal transformer mounting kit | digitalabyss | Parts | 0 | 30th April 2009 09:45 PM |
| mounting plate for transformer | dine1967 | Parts | 5 | 22nd April 2005 02:46 PM |
| Transformer mounting question | kilowattski | Solid State | 1 | 6th October 2003 03:19 AM |
| transformer mounting... | Guiness | Tubes / Valves | 9 | 8th July 2003 04:18 AM |
| Page generated in 0.07667 seconds (77.85% PHP - 22.15% MySQL) with 10 queries |
