diyAudio Sponsor
Old 2nd December 2008, 01:53 PM   #1
Default Any kit reccomendation would be helpful
i'm just building some simple, single driver computer speakers (to match the eames desk unit i built for her) for my girlfriend and I'd like to get a tube amp kit that doesn't cost too much. The drivers i'm using are the
Tang Band W4-656SC 4" Shielded Driver
Tang band w4-656sc
a half hour later i notice the have you searched checkbox.
Old 15th January 2009, 11:35 AM   #2
Empee is offline Empee  Netherlands
Empee's Avatar
Man, I love the designs of Eames'
Have you found a tube-amp kit yet ?
I don't know about kits but if you are handy enough to make
an amplifier-housing, the rest should be no problem, even if
not in kit-form. Search for "Simple EL84" on this forum
Empee
In the end, all is good
If it's not good, it's not the end
Reccomendation for easy, high-power, and somewhat crappy Class D amplifier for a sub. Spasticteapot Class D 8 20th November 2006 10:29 PM
This may be helpful to some soloxp Subwoofers 1 24th April 2006 10:42 PM
Maintaining an 8 Ohm load/Book Reccomendation Dominick22 Multi-Way 1 10th January 2006 04:47 PM
Bookshelf Speaker Reccomendation gmilitano Multi-Way 18 24th April 2004 11:06 PM
Page generated in 0.06515 seconds (76.95% PHP - 23.05% MySQL) with 11 queries
