| diyAudio Sponsor | ||
Not really audio tubes, but I have a bunch of 4Xnnn/4CXnnn tetrodes that I have plans for, however they are very grotty and rather intricate (lots of fins).
Would an ultrasonic bath be a killer for them? It would ceratinly clean them up a treat, but would it be a terminal experience Cheers!
Nicko "The whole plan hinged upon the natural curiosity of potatoes" - S. Lem |
#2 |
I'd almost rather dip them in liquid Draino...
No idea if either is a good idea, or just plain nuts??? Your sigline above tells the whole story... |
#3 | |
The photo below shows what they look like - this is a stock photo of a clean tube, not one of the many rather scummy examples I have. I was really wondering whether it would totally destroy the tubes, bearing in mind they are ceramic and quite tough...
#4 | |
Here's a little info that may be of interest. http://www.kk5dr.com/Tubes.html Victor
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#5 |
Hi there Nicko, somewhat off-topic, but if those tetrodes are the 11-pin variety could you please tell me where you got the sockets from as I have not been able to find any. Cheers
#6 |
Get you some liqui-Nox for ultrasonic cleaning, it's the best.
Nick |
#7 |
Aren't those tubes silver plated? How about the baking soda and foil method of cleaning?
#8 |
Well, I used 5 minutes @ 50C in a 3% Tikopur & water solution at 45kHz/100W.
(sort of) before and after photos below. I say "sort of" before, as the dirty tube is one that looked pretty much the same as the one I cleaned. All markings came off, but tube still seems to work fine. I finished off the silver by dipping the tube into "Goddards Silver Dip" which is a pretty standard silver cutlery cleaning dip we get here in the UK. Cheers!
#9 |
Looks pretty good to me.
Nick |
#10 |
Better view...
| Cleaning up | jackinnj | Construction Tips | 5 | 22nd August 2009 12:37 AM |
| cleaning aluminum | jaudio | Everything Else | 19 | 9th September 2006 07:26 PM |
| Cleaning tubes... | 2004ex | Tubes / Valves | 12 | 26th January 2006 01:51 PM |
| Cleaning pwc's | colden | Parts | 1 | 29th January 2003 07:33 PM |
| cleaning up the mains | NAP 160 | Everything Else | 1 | 25th July 2002 06:35 AM |
| Page generated in 0.09810 seconds (76.57% PHP - 23.43% MySQL) with 11 queries |
