diyAudio Sponsor
Old 2nd December 2008, 01:50 AM   #1
Default big ol' 26lb. output transformer...
here's one for ya. i came across a pair of diy made monoblocks recently. they used 4 6550 tubes and weigh about 75lbs. each.
i was told they were made in the early 90's.
the output tranny says "MB electronics part# 137427b".
i found a "mb electronics" on the web and called them about it but they say they are not the manufacturer and dont do transformers.
these things are huge! 6in. tall, 5in. wide, 5in. thick!
anyone have any info at all?
Old 2nd December 2008, 03:20 AM   #2
llwhtt is offline llwhtt  United States
The 137 part of the number looked familiar, it is the E.I.A. code for CTS, a big electronics corp.
I don't know if they do xfmrs, take a shot, who knows!!!
Craig
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 04:36 AM
Page generated in 0.06758 seconds (69.32% PHP - 30.68% MySQL) with 10 queries
