diyAudio Sponsor
Old 1st December 2008, 02:29 PM   #1
Default Dynaco MK IV Mystery
A while ago a friend wanted me to take a look at his Dynaco MK IV amp. The power transformer had burned up and he wanted to know if I could replace it. I was able to find a replacement PA-135 thru Triode Electronics. My friend had brought over the other MK IV and his Audible Illusions Modulus 2D preamp. Unfortunately the amp still does not work and the other amp is wired a little differently.
The big problem is that these amps were modded with 8417 and 6DJ8 tubes.
I have not been able to find any schematic or info on how they were wired. The driver board that includes the 6DJ8 tubes says mk 3 on the back and GSI 84 in the corner , but it does not match anything I have seen on the web. The boards include 2 LM 334 adj. current sources and a MUR 420 rectifier diode along with 2 pots.
The input uses a 3N259 bridge rectifier along with some very large caps(330v 750 uf).
Any suggestions would be appreciated.
Old 1st December 2008, 02:58 PM   #2
llwhtt is offline llwhtt  United States
Eric ,
Check out the Mystery ST70 board post down a few posts. Burnedfingers and I are trying to figure his out also.
Craig
Old 1st December 2008, 05:01 PM   #3
I will post some pictures this afternoon.
Old 2nd December 2008, 01:02 AM   #4
It's the same circuit, the board is just a single channel for MKIII or IV. The schematic posted by Burnedfingers should help you figure things out.
Craig
Old 2nd December 2008, 01:50 AM   #5
Default Mystery Dynaco MKIV Pictures
Here are some pictures
Old 2nd December 2008, 01:50 AM   #6
Default more pix
more
Old 2nd December 2008, 01:50 AM   #7
Default 1 more picture
1 more
Old 2nd December 2008, 03:26 PM   #8
Looks homemade, and thats a shitty wiring job.
Old 2nd December 2008, 04:56 PM   #9
"*******" about sums it up. I don't like poking around in there without a schematic, and even then, if it's "hot", 1 hand in the pocket
Old 2nd December 2008, 08:07 PM   #10
see the thread at
http://www.diyaudio.com/forums/showt...83#post1345283
for a comment about a similar board from Andy Fuchs, the principal of GSI.
Andy can probably help you out.
preamp suitable for Dynaco st-70- OTHER than dynaco namatjira Tubes / Valves 3 22nd December 2011 01:21 AM
Mystery RF amp spooney Car Audio 11 25th April 2008 06:14 PM
little 6.5 mystery ... oface Full Range 6 4th November 2007 11:20 PM
Mystery SE OPT alexmoose Tubes / Valves 4 11th July 2006 01:29 AM
mystery... mista2 Multi-Way 1 14th January 2005 04:20 AM
Page generated in 0.11034 seconds (82.39% PHP - 17.61% MySQL) with 11 queries
