6as7/6080 Se Otl - Page 4 - diyAudio
Old 3rd December 2008, 01:39 PM   #31
Fuling is offline Fuling  Sweden
Lars: Good idea but you´re not the first one to think about using an Aleph-type CCS in an SE OTL amp, I wrote something about that on this forum at least two years ago. Never got any replies though...
The whole thing would be sort of a White follower.
Old 3rd December 2008, 01:43 PM   #32
Fuling, I asked you a few posts back, remember? Just because I was sure you had already been there !
Old 3rd December 2008, 01:59 PM   #33
Must have missed that, I´ve been busy lately and haven´t followed this thread as closely as I should.
Old 3rd December 2008, 02:04 PM   #34
Fuling,
Anyway, did you ever try it? Maybe we should give it a try? I have a ICA-plasticbag with at least 50pcs 6080s somewhere in my warehouse.
Gain is -7dB with 16ohm and -10dB with 8ohm so the driver must have good voltageswing capability.
Old 3rd December 2008, 03:11 PM   #35
Lars
Do you feel the design I originally posted has good driver voltage swing as is? I have already boarded up the amp I posted just need to do some tweaks and I will try the CCS and report back over weekend
Old 3rd December 2008, 03:47 PM   #36
Lars: No, I never tested any kind of CCS load. I remember being concerned about the startup process but I don´t remember exactly why
Old 3rd December 2008, 03:51 PM   #37
It wont work, in theory anyway! Not enough swing. Will come back with an adjustment if your circuit.
Old 3rd December 2008, 04:34 PM   #38
I was wrong! It will work, but the sensitivity is very high at 100mV rms. But keep it that way, you might want to add a tad of NFB to it later.
Old 3rd December 2008, 04:53 PM   #39
poynton is offline poynton  United Kingdom
poynton's Avatar
NFB would be good anyway to reduce the output impedance etc.
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 3rd December 2008, 07:00 PM   #40
Fuling is the guy who have tried this IRL.
Simplest 6080 or 6AS7 OTL Project? Michael Rothacher Tubes / Valves 29 26th August 2010 08:05 PM
WANTED - 6080/6AS7 Based Amplifier baileyler Swap Meet 1 26th March 2008 10:17 PM
Transformer coupled 6AS7/6080 dsavitsk Tubes / Valves 48 20th September 2007 06:16 AM
Set 6080/6as7 needtubes Tubes / Valves 34 28th August 2004 04:40 AM
6080/6AS7/6H13C/6H5C in SE? Colt45 Tubes / Valves 8 18th November 2002 05:56 PM
Copyright ©1999-2017 diyAudio
