| diyAudio Sponsor | ||
#21 | |
Magneto the Gravity Man
I suggested using a CCS some time ago. OTL SE - Help Wanted with Idea However, there was concern that oscillation would (had) occured. Maybe a CCS per cathode? Andy
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#22 |
Have anyone really tried a CCS as I know you suggested? Must be the most costeffective way to go as chokes cost a lot. Just using a resistor will make you lose to much power and worsen THD.
Think a CCS robbed from Pass would be fine......
Brgds Lars |
#23 |
To be honest, I could not see why a CCS would cause oscillation and instability as it is well used, as you say in Pass designs.
And as you say, cost is minimal !!! So far, I have not had chance to try anything due to work. ( I am now 200km off the east coast of India ! ) Andy
#24 |
If you can find transformer cores, bobbins and magnet wire there´s no need to pay 60 bucks each for cathode chokes. I made my own for my SE OTL with 4x PL504 (per channel):
600 turns 0,45mm wire on EI78 cores with ~0,5mm airgap. |
#25 | |
Regards - Simon |
#26 |
Hey Fuling,
As I know you are keen to try new solutions, have you tried CCSs? My (theoretical) idea is that one could lower B+ to consist of 100V over the 6080s, the negative swing at decided load and the voltage drop over the CCS. So a std 115V secondary transformer should be sufficient.
Brgds Lars |
#27 |
This is a theoretical model of what I mean. Simmed it works well. Stole the CCS from Pass Zen and turned it upside down and changed P to N
Almost like it is too simple as the grids are at ground level. 12,5W through each 6080. At 5% THD output is 12W/16ohm and 6W/8ohm. At 1% THD output is 2,5W/16ohm and 0,5W/8ohm
Brgds Lars |
#28 |
That's pretty much what I had in my previous postigs although I cannot remember where my CCS came from!
What current have you through the CCS ? How about -ve bias for the tubes -? Andy
#29 |
Klimon: I bought my stuff from www.svebry.se
Look under "produkter", then "transformatorer" and then "transformatorbyggsatser". I guess you can write to them in english and ask if they ship abroad. |
#30 |
As I said earlier 100V/125mA through the tubes. No need to bias the tubes otherwise than with the CCS. If you check UaIa-curves, Ug is in the ballpark of -30V. So there is enough room for negative swing even if we should loose 10V over the CCS.
Brgds Lars |
| Simplest 6080 or 6AS7 OTL Project? | Michael Rothacher | Tubes / Valves | 29 | 26th August 2010 08:05 PM |
| WANTED - 6080/6AS7 Based Amplifier | baileyler | Swap Meet | 1 | 26th March 2008 10:17 PM |
| Transformer coupled 6AS7/6080 | dsavitsk | Tubes / Valves | 48 | 20th September 2007 06:16 AM |
| Set 6080/6as7 | needtubes | Tubes / Valves | 34 | 28th August 2004 04:40 AM |
| 6080/6AS7/6H13C/6H5C in SE? | Colt45 | Tubes / Valves | 8 | 18th November 2002 05:56 PM |
| Page generated in 0.10664 seconds (76.95% PHP - 23.05% MySQL) with 11 queries |
