6as7/6080 Se Otl
6as7/6080 Se Otl
Old 2nd December 2008, 12:10 PM   #11
ErikdeBest is online now ErikdeBest  Switzerland
mostly thinkerer
6as7/6080 Se Otl
Here is another one
http://www.diyaudio.com/forums/showt...ighlight=6s19p
Erik
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 3rd December 2008, 12:49 AM   #12
desperateaudio is offline desperateaudio  United States
here is the revised schematic showing how i plan to implement the cathode resistors in parallel. Again I stated earlier I have read that 6AS7's need to have separate resitors on each side of the triode to keep the current in check for the tube overall.
Any comments?
Thx
Old 3rd December 2008, 03:44 AM   #13
poynton is offline poynton  United Kingdom
poynton's Avatar
Any comments?
Thx
The large value of the cathode resistors chosen ( even though they are in parallel ) will severely reduce the output !!
Even if reduced to, say, 10ohms each, as in a previous post, the output would still be reduced.
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 3rd December 2008, 05:29 AM   #14
woody is offline woody
Instead of using cathode resistors to equalize the current draw
could you use a plate resistor on each tube? I saw this done
in the RCA receiving tube manual where a 160 ohm pot was
used to ballence the current through both halves of a 6080?
Old 3rd December 2008, 05:52 AM   #15
poynton's Avatar
Any comments?
Thx
Andy
Old 3rd December 2008, 06:04 AM   #16
Klimon is offline Klimon  Belgium
?? Looks fine to me.
I think the implementation of a cathode choke should be worthwile (raising cost with about 60$ using Hammonds), requiring lower B+ and also (more importantly, or am I mistaken?) raising efficiency. Here's a similar circuit: http://vincent.brient.free.fr/otl7w_fr.htm
Regards - Simon
Old 3rd December 2008, 06:04 AM   #17
revintage is offline revintage
To make this cicuit work you have to take out max currents through the 6080s which means their workingpoint should be Ia 125mA, Ua 100V.
You should also use a choke or a CCS from the cathodes to ground. A B+ of 130-170V will do.
Every triode has an theoretical (simplified 1/Gm)Rout of ca 140ohms, so adding a separate 10 ohm to each one will not make you loose so much. Without NFB Zout will be high anyway.
If going for a 8ohm load I would suggest using at least 5 but preferably 10 6080s/channel.
Old 3rd December 2008, 06:36 AM   #18
Here is an old circuite found on the web.
Old 3rd December 2008, 06:41 AM   #19
poynton's Avatar
Regards - Simon
A cathode choke would improve efficiency.
Your circuit (see below) has the output taken via several caps from the cathode not from the junction of the resistors so the output power would be 'unaffected'.
Also the biasing is different.
I think what is needed is a combination of designs.
Andy
Old 3rd December 2008, 06:44 AM   #20
poynton's Avatar
See post #8
Andy
6as7/6080 Se OtlHide this!Advertise here!
Simplest 6080 or 6AS7 OTL Project? Michael Rothacher Tubes / Valves 29 26th August 2010 08:05 PM
WANTED - 6080/6AS7 Based Amplifier baileyler Swap Meet 1 26th March 2008 10:17 PM
Transformer coupled 6AS7/6080 dsavitsk Tubes / Valves 48 20th September 2007 06:16 AM
Set 6080/6as7 needtubes Tubes / Valves 34 28th August 2004 04:40 AM
6080/6AS7/6H13C/6H5C in SE? Colt45 Tubes / Valves 8 18th November 2002 05:56 PM
