Tube Theory - Page 3 - diyAudio
Old 7th April 2003, 03:49 PM   #21
diyAudio Senior Member
fdegrove's Avatar
Default UH?
Joel?
Brett is siding with the Frank D. philosophy of DIY which is that any circuit that can be used in multiple applications is "bad".
Never said that either.
I just don't use single sample circuits as building blocks, that's all.
Frank
Old 7th April 2003, 04:00 PM   #22
Default ...a rose by any other name...
I suspect one of the 'failings' of CF is that they are not transparent i.e. one can always hear their insertion...but then no circuit (or component) is...
So it's an unfair 'rap'
The insertion of any single stage circuit is audiable...some slightly some a lot... Are CFs worse than other single stages? Depends on the application - sometimes they make it worse - some times they make it better... Horses for courses - again...
BTW I almost never use them (or in ss emitter followers)... I think better solutions are available...but that's just me...
ciao
James
Old 7th April 2003, 04:15 PM   #23
Joel is offline Joel  United States
Joel's Avatar
Originally posted by Brett
...There are classic designs out there that are well regarded amongst some people using CF's. In a commercial design, there is a requirement to be able to drive a wide range of poweramps, so some designers choose them. We are not so restricted in diy to the came commercial considerations.
Did you not say that?
I'm sorry if I mischaracterized your comments, but it sure sounds to me like you are saying that designing for a "wide range" of possible loads is a restrictive, "commercial" requirement.
Old 7th April 2003, 05:56 PM   #24
Brett's Avatar
You quoted me correctly in the above post, but misrepresented my statements in your earlier post.
You said <i>Brett is siding with the Frank D. philosophy of DIY which is that any circuit that can be used in multiple applications is "bad". </i> I have never said that, simply that were are able to optimise for what we are using as diyers.
Note your applied spin by the use of the words "any" and "bad".
If all my poweramps have a > 100k input Z, and my pre sufficiently low output Z, gain and drive, why design for 5k, by adding another stage with a CF, which <i>generally</i> I consider to be inferior sounding?
Then you said, <i>A "good" circuit is specialized to a single application.</i>. I didn't say that, again it's only your spin. Do you put taxi tyres on a Lambo because they're more universally applicable, and you never know, someone might want to use it as a taxi?
If you optimise something for it's desired function, then it stands a <u>greater chance</u> of being the best for that function.
Earlier I said
<i>We are not so restricted in diy to the same commercial considerations.</i>
Are you challenging that, or do you think it would be possible for ARC for example to go into production today with your 71a poweramp? Where would they source sufficient numbers of tubes? Apart from having them manufactured, not a simple or cheap proposition, then due to commercial considerations, it's not practical, whereas for a diyer it is to build a stereo amp and amass enough spares for many years of service.
Old 7th April 2003, 06:37 PM   #25
Joel's Avatar
Well, you've gone off on a bit of a tangent there. But, regarding cathode followers - somebody said earlier, and I agree, that you could very well make the same arguments against any other topology.
Old 7th April 2003, 07:21 PM   #26
Brett's Avatar
Nope, stayed on point. <i>You</i> stretched my comments beyond what I said, and all I've done is correct and clarify.
LC vs. CLC Theory Bryan Tubes / Valves 5 4th November 2005 10:33 PM
looking - theory rathek Multi-Way 1 22nd April 2005 04:58 PM
Zen theory!!! Anorgan Pass Labs 3 12th September 2003 02:53 AM
DSP theory hifiZen Digital Source 7 6th November 2001 07:18 AM
Copyright 1999-2017 diyAudio
