| diyAudio Sponsor | ||
Hi all,
Just wandering if anyone out there has tried to run a 813 in screen drive mode? I'm talking se by the way. I was thinking about trying it and was curious if anyone had any advice. Thanks, Nick |
#2 |
Just from a quick look at the datasheet, the 813 doesn't seem like a good candidate- the screen drive requirements are much too high. Ideally, you'd want a tube where something less than 200V will get the tube conducting hard (thus the suitability of high perveance sweep tubes). The 813 looks like if would want at least 400V which is a pretty challenging drive level.
In theory, you could use a stepup transformer to hit the required swing, but at those drive levels, it would be an expensive and tricky proposition.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
Thanks SY
Don't know to much about screen driving so figured I'd ask. You answered some other question I had too, thanks. |
| 6GB5 and Variants as Screen Driven Amps | wrenchone | Tubes / Valves | 25 | 18th September 2010 07:38 PM |
| Has anyone screen driven an EL84? | Lingwendil | Tubes / Valves | 11 | 22nd April 2009 03:04 AM |
| 6JN6 screen-drive (g2 driven) plate curves? | GordonW | Tubes / Valves | 26 | 23rd April 2008 01:56 PM |
| Screen driven EL36 / 6CM5 /PL36 /25E5 | Tubes4e4 | Tubes / Valves | 2 | 26th February 2006 12:00 PM |
| Transformer-driven SEPP output stage. | Circlotron | Solid State | 10 | 17th February 2003 05:14 PM |
| Page generated in 0.07455 seconds (67.13% PHP - 32.87% MySQL) with 10 queries |
