| diyAudio Sponsor | ||
I bought what I thought were Philco branded "Bad boy" 6sn7's off ebay, not labeled 6sn7 or anything at all, and plugged them in my yaqin mc-100b. They lite up just fine, but one had no sound until I tapped it, then she went. Next day sounded like it was shorting out, distorting and such. On the next fire up she went perfect as drivers, but when I put them back into the gain stage the one didn't work, and next thing the other only worked when the amp was powering down and turned off.....weird! The end result was the left channel no longer works with any tubes. I think they may have been 12sn7's or other, because during this I would occasionally place "correct working" tubes to check nothing bad was happening, but of course something bad did happen, any ideas what? Does this sound like what would happen with the wrong tube?
Here's the schematics from DIY http://www.diyaudio.com/forums/attac...mp=1200504582& |
#2 |
12SN7 won't light visibly on 6.3V. And you certainly can't hurt an amp by plugging a 12SN7 into a 6SN7 socket (might hurt your ears with distortion, depending on circuit...). But a SHORTED tube... that COULD zap something, depending on what's shorted and the circuit it's in.
#3 |
That could be, but I'm not 100% sure about the 12sn7, it could be anything that resembles a "bad boy" but I'll bet it's just shorted the way the one was acting, the other seemed OK and sounded good. I opened up the amp and didn't notice anything visual out of the ordinary, I'll check the power tubes next all the pre tubes are good ones now. Then attempt a diagnosis.
| 12SN7 vs 7N7 bs 6SN7 | jackinnj | Tubes / Valves | 7 | 28th March 2009 07:01 PM |
| 12sn7 heater-cathode voltage | alexg | Tubes / Valves | 6 | 7th May 2008 11:40 AM |
| Dropped a SIF Ba | exurbia | Tubes / Valves | 21 | 15th April 2008 08:27 PM |
| 2x 2Sk170 in place of 2SK389 and 2x 2SJ74 in place of 2SJ109? | jarthel | Parts | 12 | 26th July 2007 09:08 AM |
| Best place to place bleeder resistor in a power supply? | G | Tubes / Valves | 13 | 4th August 2004 09:26 AM |
| Page generated in 0.06586 seconds (72.38% PHP - 27.62% MySQL) with 10 queries |
