5687 fully balanced line stage
Old 28th November 2008, 10:17 AM   #1
cedus is offline cedus  France
Default 5687 fully balanced line stage
Here is something I drew yesterday.
http://ccedus.googlepages.com/full_b...687_preamp.png
This is my first line stage preamp design and thus I need the help of the ones "who know" to tell me if there is a problem with my design before I start designing the PCB.
My constraints for the project were the following.
- Use the 5687 because I have lot of them
- a fully balanced line stage which could be also used with SE sources.
- use CCS (because I never used them on any of my previous tube amp or preamp).
For info the PS is tube shunt regulated. The cascode CCS with LM317 and DN3545 comes from Walt Jung great article about CCS.
Part 1 :
http://waltjung.org/PDFs/Sources_101_P2.pdf
Part 2 :
Addendum:
http://www.waltjung.org/PDFs/AX_Letters_0907.pdf
Could someone help me to calculate the gain of the whole thing. I don't know how to handle the 500ohms degeneration resistors in my gain calculation as well as how a ccs can affect this gain.
Thanks in advance for your help
Old 28th November 2008, 02:29 PM   #2
Cauhtemoc is offline Cauhtemoc  Sweden
Default Re: 5687 fully balanced line stage
Spice can be a great help.
Old 28th November 2008, 02:44 PM   #3
...especially when everything is drawn with gEDA
But what I was waiting for are the formulas so I can calculate it by myself next time.
Old 28th November 2008, 11:36 PM   #4
Here is a new updated schematic.
http://ccedus.googlepages.com/preampv2.png
Old 29th November 2008, 01:33 AM   #5
dsavitsk is offline dsavitsk  United States
dsavitsk's Avatar
Try here http://www.aikenamps.com/CommonCathode.htm
Old 30th November 2008, 01:11 PM   #6
jmbee is offline jmbee  France
hello,
I think you can use common cathode formulas then half the gain for a differential stage. For 5687, considering Ri= 3,5 K and mu=17, that gives a gain near 14dB
(5) for assymetrical in /out.
Old 30th November 2008, 01:59 PM   #7
jane is offline jane  Norway
jane's Avatar
This spreadsheet will calculate common cathode gain and output resistance. --> http://www.veiset.net/tech/rk.xls
Jan E.
Life is hard - Then you die.
Old 30th November 2008, 07:00 PM   #8
46davis is offline 46davis  United States
Default 5687
I've been working with 5687s for a while and I think what you'll run into is a noticeable amount of distortion from the first (plate follower) stage. Even if the tube is run in a relatively straight part of the transfer curve, drawing at least 10 ma, it generates a measurable amount of second order harmonic distortion. I tried about 5% or about 4dB of local negative feedback to get it under control. Also, this tube is a real current hog making PS design expensive and it runs hotter'n hell. Other than that, great tube.
Old 23rd July 2009, 11:24 AM   #9
sajti is offline sajti  Hungary
I plan to build balanced preamplifier. I have 2 topology, and I'm not able to choose, which would be better:
The first:
The second:
Sajti
Old 23rd July 2009, 12:16 PM   #10
Hello Sajti,
In my humble opinion , the second topology has no decisive advantage
vs the first; it makes me think to a Audioresearch LS first 2 stages:
http://www.arcdb.ws/LS22/ARC_LS22_schematic1.gif
Unles you need a lot of gain, you might increase R1 and R4 for better linearity.
cordialement
jmb
5687 fully balanced line stageHide this!Advertise here!
5687 line stage costa23 Tubes / Valves 35 10th August 2008 10:53 AM
Balanced Line Stage tonistefanovski Pass Labs 1 27th December 2005 10:25 AM
Balanced Zen v5 + balanced Zen line stage Adrie Pass Labs 0 30th May 2004 06:27 PM
5687 Line Stage karma Tubes / Valves 16 3rd June 2003 10:44 PM
Zen Balanced Line Stage Balanced vs Unbalanced macka Pass Labs 28 11th December 2002 07:18 AM
