| diyAudio Sponsor | ||
i got a hold of an amp chassis that had basically the same tube compliment as a 5E3 except it is a transformerless amp with 25L6s as power tubes. i also had a power transformer that would run a 5E3, so thinking myself quite clever, I set about rebuilding a deluxe into the chassis and got rid of the old tubes. Then, after reading Jack Darr I realized I probably made a big mistake. Will the OT work? Darr was talking about replacing OTs and mentioned matching load resistances and plate to plate load impedance and a realized this material is out of my depth. i can't seem to find the same kind of data on the 25l6s that are available for the 6v6s so I can't even do a side by side comparison. Can some one lend a hand here? If I have to dump the old OT is there anything I might be able to find on ebay that will get the job done. I see a lot of pro jr. type OTs out (although i believe they run el84s) , or should I just buy a tweed deluxe replacement? Thanks |
#2 |
Maybe I need to rephrase this question -
I realize that the OT will "work" but how does one calculate how it will work optimally? What data does one use and how is it use to match on output transformer and a set of (or one) power tube? I found this link showing how to test an unknown OT http://www.diyguitarist.com/GuitarAm...lectedLoad.htm But it does not specify how this test is done for a push pull OT. Any insight would be greatly appreciated. |
#3 |
The 25L6s would use a 4KCT output transformer, and 6V6s would like about 8KCT. The 6V equivalent of the 25L6 is the 6W6 - but it probably isn't worth the trouble to get a low-voltage transformer for those (and end up with half the power of 6V6s...).
You can TRY a speaker load impedance of double the original, which will present 8K to the output tubes but you'll lose an octave from the low frequency response. You may have4 to bite the bullet and get a proper 6V6 transformer. |
#4 |
Thanks - I'm still waiting on parts so I will be able to do the "ear" test. If it sucks I'll try some thing else. Will a recycled blues jr. OT get the job done?
| Im BAAAACK! Marathon amplifier question, won't work bridged mono! | 240z4u | Car Audio | 11 | 3rd April 2008 02:56 AM |
| Answer to the Question No One Asked-A Work in Progress.... | johnbrown | Analogue Source | 0 | 7th June 2007 01:32 AM |
| Question on Gio's bipole sealed box - will this work? | pwan | Full Range | 21 | 6th January 2007 02:48 AM |
| xover question; will this work? | matjans | Multi-Way | 7 | 1st June 2004 12:29 PM |
| P3A won't work | Austin | Solid State | 5 | 3rd January 2004 09:04 AM |
| Page generated in 0.07741 seconds (76.01% PHP - 23.99% MySQL) with 10 queries |
