PCB advice
PCB advice
Old 2nd December 2008, 06:47 AM   #11
dewets is offline dewets  South Africa
Hi
I would not include the component overlay on the copperside of a valve/tube PCB.
With some of the voltages running on a valve/tube PCB you may just get an arc-over and wham!!!
But then I am over cautious and a nit picker about things that things that may go wizz-zap-wham and you smell that acrid stink of an electronic part "stepping-over" beyond it's design limits!
Great looking etched PCB there by the way. What tools process do you use to produce PCB's?
Old 2nd December 2008, 12:08 PM   #12
cjkpkg is offline cjkpkg  United States
I did the laser jet printout on a transparency. Iron it on and give it a Ferric Chloride bath...
I do plan to coat the solder side after it is stuffed...I have seen some folks recommend using just a clearcoat acrylic. Would this be OK??? Or maybe a clear polyurethane?
Any advice here would be appreciated.
Carl
Old 8th December 2008, 12:33 PM   #13
I stuffed the pcb last night...Also on the copper side I ground away some areas that looked like they could arc over.
I am waiting on a couple items for the PSU - the B+ is too high right now so I am fine tuning it to get it down closer to 250V.
Old 8th December 2008, 02:26 PM   #14
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
PCB advice PCB advice
Are this (cap-end) connected?
Arne K
Don't believe everything you think...
Old 8th December 2008, 02:39 PM   #15
Arne K
Dang it!!! Nice catch...I hopefully would have caught it before I applied power but I missed it until now...I will have to run a jumper to it now...UGH...
PCB adviceHide this!Advertise here!
first amp advice prezden Class D 2 18th November 2008 10:05 PM
TT advice??? geordie Analogue Source 2 30th September 2007 04:04 PM
Advice for an amp wyomoose Subwoofers 1 12th February 2007 08:07 PM
New to DIY, looking for advice flubhubber Multi-Way 1 14th November 2005 03:48 PM
Poster in Musical Instrument forum needs bridging advice on BrianGT 4780 advice moving_electron Chip Amps 0 16th February 2005 12:37 AM
