Wanted. Simple EL34 Push Pull Design - Page 3 - diyAudio
Old 27th November 2008, 12:29 AM   #21
I wanted other people to post before I commented.
The lack of UL taps on the O/P trafos is a major PITA. If relatively simple circuitry is to be used, triode wired "finals" seem (IMO) best. Some loop NFB around the O/P trafo rates to be a good idea. Foregoing the loop NFB requires absolutely top notch "iron" and, given the history provided, we can reasonably assume the available O/P trafos are not stellar.
A Mullard style circuit using a 12BH7 section as the voltage amplifier and a 12AT7 as the LTP phase splitter should yield a satisfactory gain structure. Reasonably high gm small signal types (like those mentioned) provide some protection against slew limiting.
Protect the O/P trafo cores against saturation, due to a LARGE low freq. error correction signal, by rolling infrasonic noise off at the amp's I/Ps.
Eli D.
Old 27th November 2008, 12:50 AM   #22
Thanks to everyone who has replied. Lots of really useful info and ideas. I am sure I will be able to procede with this now.
Old 27th November 2008, 01:19 AM   #23
frugal-phile(tm)
planet10's Avatar
Originally posted by boywonder
Planet10: I'm not sure I got your point.......the design pairs good with these or doesn't have enough damping for these?....
Many/most of those like amplifiers with low damping/high output impedance.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 27th November 2008, 05:50 AM   #24
Because they sound GREAT!
Hi Allen,
Should read: Because you think they sound great !
I think single triodes sound BETTER!
About your amps odd order distortion the odd orders would be even lower using single triodes. 2nd harmonic maybe would be a tad higher, though.
The cathode circuit in your output stage seems interesting, will dig deeper into it....
About designing correct, it goes for all circuit doesn´t it.
I simmed your circuit at 10mA through the CCS, maybe you go higher?
About other recommedations I would say: Stay away from Mullard inspired designs with their limited PI output swing and high NFB! As Allen says use high Gm tubes at higher current. So skip the 12-family. Go for 6DJ8, 6C45, 6H30, 5842 etc.
Old 27th November 2008, 11:54 AM   #25
diyAudio Moderator Emeritus
ray_moth's Avatar
Seems a bit of a sweeping statement - you sound like Morgan Jones, who didn't have much good to say for the Mullard 5-20 in his Valve Amplifiers.
I think it all depends on how you implement the topology. Mullard had an agenda with the 5-20, which was to promote their audio tubes, the EF86, ECC83 and EL34. Not only is ECC83 (12AX7) unsuitable as a phase inverter/driver, it also gives far too much gain together with the EF86. Even with the high levels of NFB used, at about 125mV RMS the amp was still ridiculously sensitive for today's signal sources.
However, there is no need to use Mullard's selection of tubes. If you implement the topology using more suitable tube types (lower gain and lower internal impedance) and reduce the level of NFB to suit, then the Mullard design is a good basis on which to build.
An improvement well worth considering to provide better balance, IMHO, is a CCS tail for the phase inverter.
Another improvement is to add a CF (or SF) pair after the phase inverter and before the OP tubes, to act as direct coupled drivers. At the same time, a change shoulld be made from cathode bias to fixed bias. This will avoid the danger of blocking distortion on transients and will also remove any influence that the changing input impedance of the Class AB OP stage may have on the phase inverter, which Morgan Jones says is sensitive to such things.
These improvements can be added later. You can start off with a relatively simple Mullard-based design, then proceed from there to improve the design as and when it suits you to do so.
Old 27th November 2008, 01:36 PM   #26
Nevertheless you agree and clarify exactly what is so wrong with it!
A CCS with negative supply would fix the swing. With two triode-strapped E280F you could skip the input tube and still adapt some small amount of NFB.
I have the Mullard book and love it! Specially the part before the 5-20 where they deal with UL and triode-strapping. They choose the wrong alternative though.........
But if you redesign it as you propose it is not a 5-20.
Old 27th November 2008, 02:40 PM   #27
smbrown is offline smbrown  United States
smbrown's Avatar
Eli, you said, "Foregoing the loop NFB requires absolutely top notch "iron" " Can you elaborate on why? Are you thinking that the low end response of the transformer might be poor and NFB would help flatten the frequency response?
Old 27th November 2008, 03:30 PM   #28
ray_moth's Avatar
I see this as a bit of a quandary. On the one hand, the defects of a poor OPT will be heard without loop NFB, as Eli suggests. On the other hand, a poor OPT can cause problems with loop NFB. The conclusion I reached is that you need a good OPT whatever you're trying to do.
Old 27th November 2008, 03:42 PM   #29
A lot of the less costly "iron" available exhibits unacceptable behavior at both freq. extremes. Loop NFB in combination with other measures deals with the matter.
As long as bass extension is "flat" to below 30 Hz., things are OK. That gets you below the deepest note a double bass can produce. Rolling infrasonic noise off at the amp's I/Ps protects against core saturation from an excessive LF error correction signal. Of course, reasonably decent magnetic headroom must be available. When "El Cheapo" was designed, we called for Fender Deluxe guitar amp replacement O/P trafos and restricted ourselves to the "6" WPC triode mode yields.
At the HF end, slew limiting due to a large error correction signal is the enemy. High gm small signal types are resistant to slew limiting and selecting them is rather obvious. However, inductively peaking the small signal HF gain reduces the net error observed at the speaker terminals. A smaller HF error there implies a lower level error correction signal.
Eli D.
Old 27th November 2008, 03:51 PM   #30
smbrown's Avatar
Eli & Planet 10, thanks for the response. In my case I'm playing with a PP KT66 that recycles iron from a Heathkit A-9c amp. I gutted most of it, changed the 12AU7 which has one stage as a voltage amp and the other as a split load phase inverter to a 6SN7. I changed KT66 from pentode to triode mode and eliminated NFB loop. To me, it sounds great. Measures flat to 15hz, and up to about 15khz before any decrease in output, down just a bit at 20khz. However, in looking at square waves I see a pronounced leading edge over shoot, not sure why. If I take a closer look w/scope the leading edge looks like a small ringing at about 200khz. I'm not sure if I should pay any attention, or if there are measures I can take to solve without negative impact on the sound. Any thoughts? I did try putting in a small amount of NFB (no comp cap) to see if any change, but none that I see.
EL34 Pentode in Push-Pull! Guijs Tubes / Valves 68 13th February 2013 08:08 PM
EL34 simple push pull class B : why 100W ? bozole Tubes / Valves 13 1st July 2009 05:26 AM
EL34 Push Pull in Class A arnoldc Tubes / Valves 29 17th May 2006 11:52 AM
EL34 Push Pull weirdness waner Tubes / Valves 32 11th December 2004 07:17 PM
Troubleshooting EL34 push pull amp psysjal Tubes / Valves 12 15th October 2004 04:21 AM
Copyright ©1999-2017 diyAudio
