| diyAudio Sponsor | ||
I do not fully understand the concept of chokes. when I am looking on digikey they were asking me about the dc resistance and current. Which parameters would be ideal for removing hum/buzz in a tube amp? the audio stage, not the power.
Would a 120ohms be appropriate? I read that amongst these forums. However all digikey items are rated down to 10mA which I really doubt thats enough. Thanks! |
#2 |
The parameter good for removing buzz is the inductance (in henries). 10H is a good general start. The gague of wire and length used determines the resistance. The smaller the core, the more turns needed for given inductance, hence the higher the resistance and lower the current rating. Digikey does not have power supply chokes. What you're looking for is a supplier of Hammond chokes, as they will likely be the best bang for the buck. The cheap overseas chokes half the time aren't gapped for DC and are woefully overrated (I have some here common as dirt sold as 90mA DC that aren't gapped at all and wound with 36AWG [good for 36mA continuous] wire!!!), so you want to avoid those. Cheers! |
#3 |
Angela.com has the best prices on Hammond transformers I've found online.
#4 | ||
http://search.digikey.com/scripts/Dk...l?name=154G-ND So does Mouser http://mouser.com/Search/ProductDeta...KrtnBU2w%3d%3d Neither generally have great prices, though the difference is often lower than the shipping from elsewhere if you are ordering other stuff. That is, if you need lots of Digikey/Mouser stuff and only one Hammond piece, you are often better off getting it through Digikey/Mouser than paying the additional shipping elsewhere. Neither have that many in stock, though I think Mouser is better in this regard. Quote:
Also, Handmade is closing out their Hammond and you might find a deal: http://www.hndme.com/productcart/pc/...idCategory=107
http://www.ecpaudio.com |
#5 | ||
Showing all non-stock here. Best to get at another place unless he has an account. Quote:
Though if he can find a dealer to ship USPS, then that would be cool, as he can get it cheaper than up here even with the extra postage Cheers! |
#6 |
would I be looking for something like this?
http://www.hndme.com/productcart/pc/...&idproduct=348 thanks for the headsup on the deal though, I'd probably get a pair of their output transformers too |
#7 |
There is a good idea for hum/buzz: Cap 1-2 mkf paralell to the choke
Try..... |
#8 |
Mouser does ship via USPS. You can choose which shipping service you want to use from them. I ordered some parts from them recently for my Fisher 400, and had the package shipped USPS.
#9 |
actually solely for cost reasons, im trying to stick to them because their output transformers are on discount =P I figured the hammonds are better than those 18$ ones mentioned else where on this forum. im not sure what you mean azazello with mkf.
thx edit: btw! whoowhoo! im outta probation =) |
#10 |
If you are talking about Edcor as the $18 ones, then you might want to check out this page Tubelab tests hammond and edcor transformers . Edcore is good value for money.
| Question about chokes | stven | Chip Amps | 7 | 13th January 2009 09:30 PM |
| Plate chokes & Power chokes | JC951t | Tubes / Valves | 3 | 19th October 2006 03:18 PM |
| Chokes 4 everyone! | Circlotron | Parts | 15 | 9th May 2005 07:51 PM |
| Chokes in PSU | diyman | Solid State | 6 | 20th February 2004 05:13 PM |
| Rf Chokes - Sos | b_online | Parts | 0 | 14th May 2003 11:27 PM |
| Page generated in 0.10714 seconds (82.26% PHP - 17.74% MySQL) with 10 queries |
