| diyAudio Sponsor | ||
How important is it to place the PS decoupling cap near the stage it decouples (e.g. near driver tube load resistor or power stage opt)? Diversifying the question:
1) Would a smaller bypass cap placed closer to the stage make up for the 'main' cap placement say 5" away? 2) What variables influence the necessity of minimal physical distance? Is a phono stage more crucial than a driver stage than an output stage / do capacitor specs like capacitance or esr make a difference? You probably get my drift by now; any elaboration on the underlying mechanism or practical input is most welcome Simon |
#2 | ||
Therefore, when using pentodes and cascodes, keep all leads as short as possible. If your tube sockets have a large, central pin, be sure to ground it as it's there to make an electrostatic shield. When installing screen bypasses, connect the outside foil to ground, and mount them across the socket so that they'll do double duty as an electrostatic shield. Install grid and screen stoppers as close to the socket pin as possible. O'scope and look for RF parasitics. With low gain stages, it's not so critical since small signal, medium gain triodes are low gain devices, as compared to transistors and some small signal pentodes. Still a good construction practice to keep lead lengths short. |
#3 |
That's very useful Miles, thanks a bunch
Simon |
| Decoupling | richie00boy | Parts | 9 | 13th November 2006 04:31 PM |
| Decoupling cap placement - virtual ground dual op amp? | Triophile | Solid State | 1 | 27th March 2006 06:30 AM |
| Decoupling caps(again) | argonrepublic | Parts | 2 | 10th May 2005 10:32 PM |
| decoupling PCM1716 | Smiffy | Digital Source | 6 | 6th February 2004 01:24 PM |
| Page generated in 0.07570 seconds (74.28% PHP - 25.72% MySQL) with 10 queries |
