ecc40 LTP - Page 2 - diyAudio
Old 22nd November 2008, 06:17 PM   #11
Some interesting information!
I just went to Mouser and saw they offer free Fedex shipping to the Netherlands for small (volume wise) orders over 75 euro. Seems to be the right time to get that small stash of DN2540's, and maybe some 10M90S!
Erik
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 22nd November 2008, 07:39 PM   #12
Jaap is offline Jaap  Netherlands
Jaap's Avatar
Default the ccs is not the problem
Originally posted by hemgjord
It would look like any diff stage. If you want suggestions regarding komponent values, operating points etc. I think you have to be a little more specific as to the intended use, available rail voltages etc.
/Olof
I would like to use an interesting power stage with 6CB6A pentode driving a pair of el34's in push pull with local feedback. It is published in Glass Audio 4/95 (design Berglund). See attachment.
Perhaps I try a regulated screen supply on grid 2 of the el34's.
As a splitter before this powerstage I thought of a ecc40 LTP with ccs under it. B++ will be between 300 and 400 Volt.
Problem is what operating point, component values, etc.
First question is: is this constellation feasible ?
Old 22nd November 2008, 10:00 PM   #13
diyAudio Moderator Emeritus
ray_moth's Avatar
Yes, the circuit is certainly feasible. I'm modeling it right now with LTspice, using 6SN7 LTP splitter with BJT cascode CCS tail, 6AU6 drivers and EL34 outputs. I think the OP transformer should be for 3.5k p-p load, not 5k. With B+ = 480v at the OP transformer CT, available power is 54w with input signal of 900mV amplitude (630mV RMS) @ 1kHz.
It models well with added global NFB and some jiggering around with correction networks to remove the peaks at low and high frequencies. I use a step-network to couple the LTP to the pentode drivers, because that gives better LF stability for my purposes. Adjustment is necessary to the shared cathode resistor of the drivers, because the step network elevates the grid and cathode voltages.
Old 22nd November 2008, 11:09 PM   #14
Originally posted by SY
You can do it three ways: find a 50V FET with an Idss somewhere nearby and do some selecting, find a 50V FET with an Idss higher than you want and use a source resistor to bias it correctly, or (my choice) use any old 25 or 30V FET with a series resistor to drop most of the voltage, leaving 10V or so across the FET. The rationale is that there are hundreds of usable 25V FETS, but very few 50V ones.
Alternatively, you could use a DN2540 with a source resistor. Overkill, but they're cheap.
One more thing to consider is a cascode of DN2540 instead of the bipolar CCS. No reference string, super low parts count and expense, extremely good performance. I've seen some fancy ones, but I've posted schematics of a dead simple one, just two FETS and four resistors. I suspect that you'll see this circuit in the 4th edition of Valve Amplifiers.
Very helpful post. Can I ask where you posted the schematics for your DN2540 cascode? Or could you post them again in this thread? I have some IXYS 10M45S. Can these be just dropped in for the DN2540 or do they require anything different. I'm quite ignorant of solid state, so may need a bit of hand holding here!!
andy
Old 22nd November 2008, 11:34 PM   #15
SY's Avatar
Here it is. The two gate resistors are gate-stoppers, value not critical but keep the resistor bodies as close to the gate lead as possible. R5 sets the current- for the particular batch of FETs that I got, 300R yielded a 10mA current. That might be different with a different batch, so I'd set up a test jig and pick a resistor to get you the right set current. I found that once I determined the right resistor value, all the FETs in that tube gave me pretty close to the same current.
File Type: pdf fig 5 high voltage fet cascode current source.pdf (17.1 KB, 139 views)
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 22nd November 2008, 11:35 PM   #16
SY's Avatar
And, anticipating the next question, here's the test jig.
File Type: pdf fig 7 current set resistor test jig.pdf (18.7 KB, 100 views)
Old 23rd November 2008, 12:00 PM   #17
Thanks SY! Two questions:
1) Can the IXYS 10M45S be dropped in the same circuit?
2) Can this be used for input stages with small bias voltages like 0-5v without having to run it off a -15v supply?
andy
Old 23rd November 2008, 12:22 PM   #18
SY's Avatar
1. I haven't used that device, but if it's a depletion mode device, it'll work. You'll just have to determine the correct bias resistor value.
2. I'd want more voltage across it, especially because of the signal knocking out a volt or two of the headroom. Either a separate negative rail (easy and noncritical, since the CMR of a diff amp is high, and the CCS itself forms a divider with the looking-in resistance of the cathodes) or lifting the grids above DC ground by a few volts (also easy with a voltage divider). Same with the bipolar unit- you want at least 5V across it, more would be better.
ECC40 driver stage for 2A3 cypher Tubes / Valves 3 24th August 2008 07:56 AM
ECC40 preamp Hojvaelde Tubes / Valves 7 7th November 2007 01:04 PM
ECC40 cascode Jaap Tubes / Valves 3 28th December 2006 09:00 AM
Can ECC40 be used in a phono stage? andyjevans Tubes / Valves 1 6th January 2006 12:33 AM
ecc40 or 76 as driver for 2A3 Jaap Tubes / Valves 3 28th May 2004 09:36 PM
Copyright ©1999-2017 diyAudio
