| diyAudio Sponsor | ||
I am at the early stages of building an Aikido 5687 line stage. I also want to integrate RJM's 6DJ8 phono stage into the chassis for an all in one preamp.
I have all the iron figured out - I am using a separate 12.6V xformer for all heater needs - it is a 3A unit which just gets me there. My main question is, if I use the preamp primarily for non-phonograph use, how can I easily cut B+ and heater current so that I am not running the tubes when they are not in use? My target B+ is 250VDC. Would a standard DPST switch rated at 250VAC be sufficient? |
#2 |
Presumably a double pole switch, with one pole cutting the HT and one pole cutting the heater supply to the phono section.
A 240V mains switch should survive- everybody uses them. The current levels are so low that you can over-voltage them quite a bit and still get long life. Alternatively, you could just switch a resistor into the heater circuit so that the phono valves run with a reduced heater voltage (about 6V say), which will allow them to idle at reduced temperature. Since you're only dealing with low voltage, the switch rating won't be a problem. |
| Aikido All in One line stage amp PCB | Evenharmonics | Tubes / Valves | 13 | 24th October 2009 04:33 PM |
| Aikido Line Stage | Bengali | Tubes / Valves | 6 | 10th September 2007 11:51 AM |
| Improving the Aikido line stage... | Bas Horneman | Tubes / Valves | 144 | 10th February 2006 05:00 AM |
| Page generated in 0.08516 seconds (69.65% PHP - 30.35% MySQL) with 10 queries |
