Irritating problem with soft start
Old 19th November 2008, 01:02 PM   #1
Rob11966 is offline Rob11966  Australia
Rob11966's Avatar
Default Irritating problem with soft start
Hi folks,
I have an irritating problem with this soft start circuit.
I have breadboarded it up and it seems to work with a light bulb load but when I was checking the relay coil voltage, I noticed that it just kept climbing. I shut it down when it got to about 31V
Mutliple tests, swapped all components (except relay which is new) same result - the voltage climb rate is slow - it takes maybe 180 sec to increase from 24 to 31V but never looks like reaching a plateau, just a slow steady climb. Have tested with heavier loads with the same result
The coil is rated at 24 volts as per the schematic. I increased the 220 ohm resistor to 240 ohms (using 240AC input), otherwise the circuit is identical.
Does anyone have any idea what is going on? Obviously I am concerned that if the voltage keeps rising it will burn out the relay coil, the 35V caps or both.
Thanks for any input this is bemusing me.
Rob
I have attached the slow start circuit, it is from Andreas 845 amp.
The full circuit diagram is here -
http://www.audiodesignguide.com/New845/New845v2.html
Old 19th November 2008, 01:20 PM   #2
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
Increase the resistance from 240 ohms to perhaps 330 ohms.
Select the value which will give you 24 volts or less on the relay coil after the voltage stops rising.
Your relay coil may draw less current than the coil that was used in the original amplifier.
Frank
Old 19th November 2008, 01:44 PM   #3
Rob11966's Avatar
Hi Frank,
Did that - even increased to 1k. with a 4W resistor. Little change but the resistor got pretty hot. The relay draws 20 mA and this may be the problem I think. I did a quick calculation and got a value around 11K at 4.4W.
May try a couple of resistors in series to see what happens.
Rob
Old 19th November 2008, 01:50 PM   #4
don't use the raw mains to feed the delay side of the relay.
Use a separate 20Vac transformer that comes on with the power switch.
Keep the mains side to the relay contacts.
Live comes to one relay contact and Live leaves the other relay contact.
Edit:
your posted schematic is misleading. It has omitted the 2 from 220Vac to leave 20Vac showing.
I still do not recommend using mains by that method.
Do you realise what will happen if one or both of those caps starts to fail to shorted?
Edit2:
the 240Vac mains ~340Vpk.
at 240Vac the 440nF caps pass~46mA. At this current draw the 220r resistor drops 10V. That leaves ~330Vpk to charge the 35V caps.
If the relay draws that 46mA then it stabilises the voltage across the caps. But if the relay current does not balance the supply through the caps the bridge will keep on charging the smoothing to >300Vdc. Eventually the smoothing cap leakage will balance out the total current passing the 440nF.
But what happens in the meantime?
We could modify the circuit for better operation. But that still leaves a dangerous situation for anyone that chooses not to follow the modifications to make it safer and more reliable.
I am going to report this post to the Moderators.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 19th November 2008, 02:07 PM   #5
Rob11966's Avatar
Thanks for the advice Andrew.
Sorry about the schematic, you are correct, it should read 220VAC. I chopped the 2 off the front whilst copying.
I just used 4 x 2.2K 4W resistors in series with good results, so the problem clearly is the resistance of my coil (thanks Frank). Whilst this did work the resistors still got pretty hot.
Andrew, I like your idea of the 20VAC transformer. I need 12V for my LEDS , so I might get a center tapped 20 V transformer to run both the LEDS and the soft start relay.
With regards to the caps failing with the mains, I did not tink it through and it is now 2 am so can't think straight but by the sounds of your email it is obviously not something good .
Thanks again,
Rob
Old 19th November 2008, 02:10 PM   #6
go and read ESP for safer ideas on soft starting and his warning on using mains power for the delayed bypass relay.
regards Andrew T.
Old 19th November 2008, 03:59 PM   #7
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
If you MUST use capacitors, use safety rated "X" capacitors, which are rated for mains use. Essentially, they act as a 30 mA constant current source, so as the relay coil heats (and its resistance rises), it consumes more power, which makes it even hotter... add a 24V zener diode in parallel with the coil.
Old 19th November 2008, 04:24 PM   #8
That Zener is going to get hot
Should we be advising on altering a potentially dangerous schematic?
regards Andrew T.
Old 19th November 2008, 05:45 PM   #9
leadbelly is offline leadbelly  Canada
leadbelly's Avatar
Originally posted by AndrewT
[BShould we be advising on altering a potentially dangerous schematic? [/B]
Indeed. Since the poster has indicated that the circuit is attached to the mains the thread should be closed IMHO.
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Old 19th November 2008, 07:11 PM   #10
Tom Bavis's Avatar
So we'll only discuss battery operated amplifiers from now on? Mains circuits should use components rated by safety agencies for the purpose. I see no reason that can't be done with the original circuit (of course there may be a BETTER circuit - isn't there always?).
As for the zener getting hot, it will see about 10 mA at 24V - 0.24W
Irritating problem with soft startHide this!Advertise here!
Elektor soft start circuit problem supernet Solid State 15 23rd July 2010 10:11 PM
B+ soft start Gluca Tubes / Valves 2 3rd September 2007 01:04 PM
Need a soft start? maxpou Solid State 19 18th April 2007 09:23 PM
Soft start & Soft Switch circuit: can anybody help? m.parigi Solid State 95 22nd August 2005 03:32 PM
Copyright ©1999-2017 diyAudio
