Effects of high heater voltage?
Old 18th April 2003, 12:26 AM   #21
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Default Re: Paradox.
Originally posted by fdegrove
Cathode poisoning is one of the reasons.
It may take a lenghty explanation of what exactly goes on here, maybe someone more clever than me can condense it in a few lines....?
I didn't know that cool cathodes could provoke cathode poisoning. Why?
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 18th April 2003, 12:48 AM   #22
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Exclamation POISON.
It does, as I said earlier it may take a lenghty translation exercise on my part but rest assured it's not healthy for the tubes.
Granted, the study is based on MTBF studies done on CRTs but it applies to any tube really.
The documents were publishished by the Dutch (defunct?) mag Audio & Techniek and covered AC versus DC heating etc.
The invitee was an ex Philips engineer, the redaction plus some audionuts such as Audio Note importer Ed de Jong, some other people I can't quite remember and yours truly.
This poisoning is one reason why I so often object on totally unnecessary stand-by arrangements such as leaving 1/2 B+ on the anodes or reducing heater voltages by half and so on.
One can actually create new types of tubes by "forming" them on particular voltages for a while, it seems tubes have some kind of memory as most other parts but I'm pushing...
If you like I can dig up that document and mail it to you, it's slightly over 1 Megabyte in size and in PDF format thanks to fellow member Remco (AKA Analogue something...).
Frank
Old 18th April 2003, 12:59 AM   #23
fdegrove's Avatar
Default STANDING OVATION.
May I soundly applaud you on your desire to find about more about the valves you use!
Absolutely...wish we had more members like this.
Quite refreshing after a long series of the kind look Ma what I found in the junk box...anything I can do with it ?
How do I tack this odd-ball to that one, etc and manage to drive half the forum nuts with impossible questions.
Sorry to sound harsh,
Frank
Old 18th April 2003, 01:02 AM   #24
EC8010's Avatar
Default Re: POISON.
Yes, please.
Just to add confusion, studio tube cameras always ran their tubes in standby to extend their life. (63% heater voltage, then full heater voltage, then HT after one minute delay.) Each of our four cameras used four tubes, and at 1,500 a pop, you really wanted to get every hour you could out of them. They typically lasted 3,000 hours, although we had a couple that were 17,000 hours old, and still producing nice pictures.
Old 18th April 2003, 01:22 AM   #25
fdegrove's Avatar
Default NO CONFUSION HERE.
Remind me to send this to you, ( I'm going to be busy for weeks to come) mind you it is in Dutch so you will have to run it through one of those magnificent translation engines.
After that you may be able to collect on a big bonus from your employer...
Ciao,
Frank
Old 18th April 2003, 01:43 AM   #26
EC8010's Avatar
Default POETRY
I look forward to seeing the results of passing a technical paper through a translation engine!
Old 18th April 2003, 01:50 AM   #27
fdegrove's Avatar
Default LYRICS.
Don't despair...I'll help with my lousy English.
Frank
Old 18th April 2003, 02:15 AM   #28
EC8010's Avatar
Default The state of education
Sadly, your English is better than the majority of (UK) students. What do they teach the kids at school? Whinge, gripe, whine.
Old 18th April 2003, 07:13 AM   #29
Jocko Homo is offline Jocko Homo  United States
Banned
Default Mr. Microwave speaks.....
In the world of microwave TWTs, heater voltage is very tightly controlled for maximum tube life and performance. Too high, and yep, it dies too fast. Too cold, the tube gets "gassy", and emission goes down.....which leads to high helix current, and......etc....
In brief, it kills tubes also. I would assume that much the same applies to conventional small signal tubes. Although I suspect lower heater voltage.......within reason......... would not have as great a negative effect.
Jocko
Old 18th April 2003, 07:42 AM   #30
Elso Kwak is offline Elso Kwak  Philippines
Banned
Send a message via Yahoo to Elso Kwak
Cool Tube Life
My uncle was most of his professional life into tubes.
He found that halving the cathode-anode voltage at least doubled the life time of the tube.
Elso /not into tubes.
Effects of high heater voltage?Hide this!Advertise here!
DC Heater Voltage Bengali Tubes / Valves 9 2nd February 2009 05:19 AM
Too low heater voltage? jkeny Tubes / Valves 6 26th August 2008 01:08 AM
Effects of voltage drop??? kyrie48 Solid State 1 25th October 2007 09:29 AM
High Voltage Heater info mashaffer Tubes / Valves 2 20th June 2007 04:47 AM
DHT heater voltage zobsky Tubes / Valves 23 9th September 2006 04:55 PM
Copyright ©1999-2017 diyAudio
