Old 22nd November 2008, 06:56 PM   #91
You gotta be kiddin me.... This thing works fine on 48V?
Don't seem to tolerate much other simultaneous abuse,
but 48V supply definitely works. With no circuit changes
to accomodate the decrease.
Now I can't seem to load the ouput any lower than 4K7,
or it distorts pretty bad. And below 2K2 the sim hangs...
I can't verify the actual load impedance of half amplitude,
in this state of starvation, but its sure lower than 2K2.
It works very nice with loads above 4K7.
I had the DAC outputs swing 2V apiece, and no common
mode or power supply noise in this run.
Works even better (at48V), replacing plate resistor with
a choke. I tried 4H 100ohms, driving 1K loads no probs.
Old 22nd November 2008, 07:09 PM   #92
Michael Koster's Avatar
Very nice, Ken,
Adding the signals together in the totem pole is brilliant!
That plus balanced ripple gets you some kind of award...
Plate feedback and that 47K bridge makes it all work.
I keep getting smoke out my ears when I try to work out
the gain and balance equation. Iterate with spice?
The triple play would be adding balanced input impedance
Plate feedback is da stuff for circuits using high-gm low-rp tube
circuits.
Michael
Old 22nd November 2008, 07:24 PM   #93
The triple play is there. Both ends see 47K.
The difference node is near zero impedance.
Difference input sees 47K to a virtual ground.
Driven in true diffferential, the sum node is
very high impedance. Sum input driving into
a voltage node the same as itself. I added
a 47K appendix to ground on the left edge,
specifically to make the input Z's balance.
It also completes a circuit to bleed the grid.
DC loading might be a little different, but
as long as the DACs aren't bothered by it,
the tube stage don't mind.
Old 23rd November 2008, 02:19 PM   #94
sunrise's Avatar
Send a message via ICQ to sunrise
oh man ... i just wanted an idea for a nice little tube output stage ............
thnx for the effort........
when you burn it - burn it good
Old 24th November 2008, 10:10 AM   #95
Three caps in the signalpath, feedback, SRPP. Those ingredients says NoNo to me .
Kenpeterinstead of that overworked "wako2", I would stick to the KISS Diff-CF.
Old 24th November 2008, 11:35 AM   #96
sunrise's Avatar
revintage - tha is exactly what i had in my mind.... to use exactly that circuit in your previous post...........
Old 24th November 2008, 12:08 PM   #97
Donīt use the BD140 though. Go for somtheing that can take a little more voltage.
Old 24th November 2008, 06:02 PM   #98
sunrise's Avatar
mje350
Old 24th November 2008, 06:10 PM   #99
Good, classic choice!
Old 24th November 2008, 06:10 PM   #100
mostly thinkerer
Hi Revintage
Is that 330pF capacitor doing the same thing as the cap in your first schematic (the one with DN2540 and negative rail)?
The filter between the cathodes had to be added to adjust a 2dB lift from 100kHz that I can not explain.
And, if the input is referenced to ground, would it work better if connecting the cathode resistor to a negative supply, say 12V?
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
6384 tubes + transformers jean-paul Swap Meet 1 20th March 2009 06:50 PM
Private reserve sale : transformers and tubes! rjm Swap Meet 4 6th December 2008 02:43 AM
Telefunken Transformers and Tubes: $50 pjanda1 Swap Meet 3 14th December 2007 10:00 PM
6P14P tubes and output transformers Wavebourn Swap Meet 12 3rd April 2007 08:49 PM
Lots of parts on Ebay!!! Tubes, transformers etc... mwmitchell Swap Meet 0 19th December 2003 06:21 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright Đ1999-2013 diyAudio
