While working in the metals shop today, I started wondering what would happen if I connected the electrode holder to the top cap of a tube and the ground connection to the cathode. I'm guessing it wll melt in a matter of seconds? Anyway, just wanted to get your opinions before I try it.
In the immortal words of Socrates, "I drank what!?" |
#2 |
I suggest you send Tubelab a message, he has extensive experience in these matters.
#3 |
arc welder at around 100V open circuit - not enough to strike an arc in the valve...
"Folks, you can't prove truthiness with information. You prove truthiness with more truthiness. In a process known as truthinessiness." - Stephen Colbert, The Colbert Report |
#4 |
YEah, I thought about that... so maybe I'll just break the envelope first to allow some air in to ionize
#5 | |
The only way to get some fireworks started is to apply voltage to the heater. Next the plate voltage supply needs to be current limited or else the little strap that connects the cathode to the pin will blow like a cheap fuse. This is the weak link when seriously abusing a tube. The cathode is the next thing to go. Some of my best meltdowns involve a plate to plate plasma in a gassy tube. The plate connections are usually made with stiff heavy wire, so they don't burn out. Connect one section of a dual tube up in the normal manner (I used a 6AS7). Operate this section far above its ratings so the plate glows. Get it hot enough so that it can act like a cathode. Apply a more positive voltage to the plate of the other section and current should flow from plate to plate. Work the current and voltage just right to get both plates glowing, let it get hot and then a plasma should erupt between the plates. When the glass starts to melt it will bulge outward indicating a positive pressure inside the tube.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
| Arc Welder Transformer used to power Amplifier | John Biles | Solid State | 53 | 18th July 2011 04:17 PM |
| Tube Noob! need help with tubes lots of tubes | therapy_fan | Tubes / Valves | 15 | 29th January 2009 09:01 PM |
| WTT: Various tubes for 6CA4/EZ81 rectifier tubes | GordonW | Swap Meet | 4 | 27th August 2008 12:37 AM |
| What's a good Welder | Seraph | Equipment & Tools | 7 | 12th August 2008 12:15 PM |
| My New Tig Welder!! | peace brainerd | The Lounge | 5 | 23rd April 2007 11:19 PM |
