heater voltage
heater voltage
Old 16th November 2008, 08:03 PM   #1
Jaap is offline Jaap  Netherlands
Jaap's Avatar
Default heater voltage
I have a transformer with 5V/2A.
I need to feed two 807 tubes (6,3V/0,9A each)
Is it useful/possible to rectify the 5V and will it deliver enough volts/current for the tubes in this way ?
Old 16th November 2008, 08:48 PM   #2
simplicisius is offline simplicisius  Serbia
you simply dont have enough power in trafo. need 11.34W, and you have only 10W.
Old 18th November 2008, 10:05 PM   #3
46davis is offline 46davis  United States
I tried what you're thinking with a couple of current hog 5687s. What I didn't figure on was the more than 1v forward current drop in the big bridge rectifier that more than ate up all the p-p benefit I was hoping to get. Sorry, won't work.
It IS ok to suck a little more than rated current from a heater winding of a p trans if you're not using another of the windings, like the 5v rectifier heater winding.
Old 18th November 2008, 11:39 PM   #4
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
A bridge and boost regulator can give you 6.3V... but not 1.8A - as mentioned, there isn't enough transformer.
heater voltageHide this!Advertise here!
DC Heater Voltage Bengali Tubes / Valves 9 2nd February 2009 04:19 AM
Too low heater voltage? jkeny Tubes / Valves 6 26th August 2008 12:08 AM
Need Help Setting Heater Voltage cgrums Tubes / Valves 10 25th January 2008 05:40 PM
DHT heater voltage zobsky Tubes / Valves 23 9th September 2006 03:55 PM
heater voltage: why ac, and not dc? alex278 Tubes / Valves 18 7th October 2005 12:21 PM
