Question Conrad Johnson reg. psu? - diyAudio
Old 16th November 2008, 10:24 AM   #1
Default Question Conrad Johnson reg. psu?
Could anyone explain to me why the resistor from the + rail to the base of both serial regulating transistors are missing?
Is the control from the two 33v Zeners sufficiant?
Anyone who knows the plate voltage for the Conrad johnson MV75 input and drivertubes?
Best rgds
Kim
Old 16th November 2008, 12:42 PM   #2
SY's Avatar
That doesn't look like a CJ drawing, and there's several things there that don't make sense. I wouldn't trust it.
That said, a buffered Zener was the standard regulator that they used. Very, very mediocre performance. You can do much better.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 16th November 2008, 12:47 PM   #3
SY's Avatar
http://www.triodeel.com/cjmv75.gif
This is the more complete schematic. The bottom Zener is NOT marked 33V, which was a suspicious value. It's probably 390V or thereabouts.
Old 16th November 2008, 03:21 PM   #4
Default Hi SY
I could not understand the circuit with the specified 33v zeners - you are probably right about the 390V.
I got another circuit that may do the job better.
Rgds.
Kim
Old 16th November 2008, 03:44 PM   #5
Default Another reg. psu!
Another regulated psu for pre and driver tubes!
Any suggestions for simple reg. psu's are welcome!
Old 18th November 2008, 04:16 AM   #6
Default Regulated power supply
Check out this link from the antique radio board. The last post from Terry Judkins contains a schematic I like and I have it about half assembled but I decided to use a dartington chain to get the current up a bit. Havn't got it built yet so I can't comment on performance.
LINK
Old 18th November 2008, 10:51 AM   #7
SY's Avatar
Maida works great in that application. I used a simplified version as the screen regulator in the Red Light District amp; it would be perfect for regulating the driver stage. Simple, cheap, higher performance than the Zener-with-a-buffer types.
Old 18th November 2008, 03:22 PM   #8
Default Re: Regulated power supply
LINK
Hi Dave,
Have tryed your link - could not get the page for the moment.
We have worked with a high volt low impedance psu . The mosfet's used limit the in voltage and of cource the output current. The only component missing on the drawing is one 150u/450-500V capasitor connected from the output +B to GND.
I have used this circuit together with a stereo version of ECLL800 as o/p tubes and a single ECC83 as driver. ( two EM87 for fun VU meters). The current dilivered was approx. 60mA and 307Vdc -- very steady high volt psu up to 400V. I have been looking for N-fet's up to 500V and I found from ST one P4NK50Z 500V type. I only need some few mA for driver and inputtube.
I would like to try with this fet.
Rgds Kim
Old 18th November 2008, 05:18 PM   #9
Default PSU reg.
Could not find anything better for psu regulation around than the two circuits already used.
Please find the bipolar and fet regulation on my amateur site.
Rgds
Kim
Old 18th November 2008, 07:25 PM   #10
Default Re: Re: Regulated power supply
Originally posted by kimjul2005
Hi Dave,
Rgds Kim
The link in the first thread is jammed up, but ignore that, page down to the second to last post and review that circuit.
Conrad Johnson Premier 350 Tube_Dude Solid State 0 30th January 2009 06:49 PM
Conrad Johnson Sonographe SA-250 crossroads Swap Meet 1 3rd February 2008 07:40 AM
Conrad johnson topology Stefano Tubes / Valves 14 1st August 2003 04:32 AM
conrad johnson help efoda Tubes / Valves 3 24th January 2002 03:23 AM
Copyright 1999-2017 diyAudio
