S-5 K-16LS Kit arrived in Germany !!
Old 15th November 2008, 09:52 PM   #1
lufton is offline lufton  Germany
Default S-5 K-16LS Kit arrived in Germany !!
Hi to all !
Yesterday my S-5 K-16LS Kit with the PL Stereo Tube Preamplifier
from S5 Electronics arrived.
Sadly the German Toll costs nerves !!
The turnover tax on imports and toll is for Germany
€ 49,- !! Thatīs US $ 61,- and the freight is $ 66,- extra.
Thatīs a lot !
But the kit is a very good piece of craftsmanship.
Nothing is missing on this kit. The PCBīs are very clean and the
construction manual is traceable. The building time for this kit was
one and half an hour. By the way, the main switch is horrible !
No German electrican will use this switch because itīs too unsafe !
Tomorrow I will start with listening. I think the best speaker
for this amp will be my Buschhorn MK II with the Fostex FE 103.
But here is my question to all of you:
What do you think about the output transformers ?
I think that they are a little bit gnomish.
O.K. in the last time my projects were SE amps with the EL34
and the output transformers were a big packet of iron.
Thank you for your answers and sorry for my bad school English !
Greetings again from Hamburg / Germany and God bless you !
Lufton
Old 15th November 2008, 10:21 PM   #2
kevinkr's Avatar
230V power transformer? Make absolutely sure before you plug it in. If not get a small auto-transformer.
The duty and shipping does sound expensive..
The small output transformers are reputed to be reasonably good, but I have heard of people replacing them with custom made Edcors.. There are several transformer makers in Germany who should be able to provide upgrade iron if you decide to go that route.
I haven't heard one of these amplifiers so I can make no comment on their sound.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 16th November 2008, 12:10 AM   #3
Dear Kevin,
thank you for your answer.
The kit has an transformer for 120 + 120 volts and
a switch to 240 volts.
Tomorro I will do my test. I think the sound depends only
on the transformers. We will see.
Good night to you, in Germany itīs 00:40 in the night.
Lufton
Old 16th November 2008, 03:52 PM   #4
Hi !
Unfortunately one of the 6005 tubes has a manufacturing error.
On the photo you can see that the glass mould is full of air pockets.
As I want to push the tube into his socket the glass break
and one my fingers gets hurt. Ooouch ! Aarrrgh, itīs hurting !
In the attachment a photo of the tube socket (without blood).
Now I am waiting for an new tube. The listening test is paused.
Lufton
Old 16th November 2008, 08:07 PM   #5
Mr. Triatic is offline Mr. Triatic  Sweden
Mr. Triatic's Avatar
check with fragjanzuerst.de he will have some new tubes for you!
www.joddla.net/audio/
Old 17th November 2008, 02:01 PM   #6
Dear Triatic,
he,he ! You are right ! Iīve orderd a new set of GE 6005 from Mr. Wüsten What do you think about his offers ? I think he has the biggest and best offer for tubes in Europe. Have a look for his output- transformers. A superb quality for a "best buy" price.
Lufton
Old 17th November 2008, 10:35 PM   #7
i like the transformers from frag jan, cheap and well made, even the really cheap ones sounds fairly good!
Old 18th November 2008, 03:46 AM   #8
rockgardenlove is offline rockgardenlove  United States
When you listen make sure to tell us what you think!
(Ich habe schlechtes Deutsch in der Schule gelernt! Ich habe nichts wichtig zu sagen. Aber es macht spaß, Deutsch manchmal zu verwenden. )
Old 18th November 2008, 10:59 AM   #9
damilkman81 is offline damilkman81  United States
Default Cap upgrade
Guten tag,
I have built two of these kits and think that they sound fantastic. The mods are helpful and the best improvement for the money has been the front end capacitor upgrades as explained in other threads. I have also experienced a broken 6005 tube. they were mass produced and it seems that about one in ten has a flaw. I think they put out a great sound though. My brother has a set of home built 4 ohm Cerwin Vega three ways with 12" subs and they sound beautiful. I am running them through a set of Phase Tech three way 8 ohm that sound just a bit better although the low end seems to start clipping a little sooner. I have played everything from the Three Tenors to Led Zepplin the music is better than I remember it ever sounding.
Tcuss Tchau.
Old 19th November 2008, 10:59 PM   #10
Hello !
After receiving a matched oktett (!!) of new tubes 6005 National Electronics NOS I was able to start my listening test with the
Buschhorn MK II with Fostex FE 103.
First start of the amp:
A smooth glowing of the tubes and no resistor or capacitor
blows up. Yea !
But a loud HHHMMMM !
O.K. we are in Germany. So I can use the German called "Schutzkontakt" = safety contact of the "Schukostecker" =
safety contact plug.
This third wire of this plug connects directly to the earth. On the PCB from S5 is a soldering point for the connection of earth. The suggestion from S5 is to connect this point with the protective steel sheet of the output transfomers. O.K. this reduces the HHMMMM
a little bit. After connecting the earth of the amp with the earth of the "Schukostecker"- earth, you can guess what you will hear ?
Nothing, only silence !! The HHMMM is gone !
Fine ! No HHMMM and no HISSS !
Part two
Connecting my Sandisk Sansa e260 pimped with Rockbox 3.0.
Looking for my prefered song: "Jazz at the Pawnshop"
decoded with ogg at quality setting q3.
Wonderful ! Crisp highs, transparent mids, and a loud and clear bass. By the way, the Buschhorm MKII can do really 50 Hz
with a full sound pressure. But you have to place them into a corner.
But after a period of listening I noticed some background noise
from the sansa while listening. Hmmm...
After switching to my CD walkman Philips EXP 2540
a door and a curtain were opened.
Finest highs, warm but transparent mids and a firm bass.
Itīs an avatar !!!
Part three
Connecting the amp to my Klein + Hummel SL30 with the
Electro Voice T35. I know that the Klein + Hummel needs more
power the S5 did his job to low volume. But not more.
O.K. this was the wrong partner.
Part four
Phoning my neighbour. He is infected with the same hifi virus.
His listening combination is a amp from REVOX A 78 and a
Klipschhorn made by ACR. It is a copy of the Klipsch from the
80ī.
Connect the amp to the Klipsch and connect the REVOX tape deck
A 77 high speed.
WWOOOOW ! Yeah !!!! Thatīs it !
I never hear before such a sound. With the REVOX it sounds
boring. But with the S5 amp we felt as if we are in the seventh heaven !
You can imagine what my neighbour wants ?
He asked to me if" I want to import another amp from America
because this amp has changed his lording."
In a short form. I have to import a new amp.
Thank you S5 for your wonderful little amp !
Best whishes to all of you. And god bless you !
Lufton
S-5 K-16LS Kit arrived in Germany !!Hide this!Advertise here!
Review of New S-5 K-16LS Kit fenpark15 Tubes / Valves 155 19th September 2014 11:03 PM
K-16ls kevin.dickerson Tubes / Valves 7 27th April 2011 01:37 AM
K-16LS Help Please Madmen Tubes / Valves 6 10th December 2008 09:26 PM
S-5 16LS tube amp use with 8 ohm speakers 123rmp Tubes / Valves 8 13th April 2008 11:40 PM
New parts arrived & will foloow with kit, !!!!S1 12pcs arrived from Holland!!!! tube-lover Swap Meet 1 3rd September 2004 11:29 PM
Copyright ©1999-2017 diyAudio
