12ax7 srpp dac output
Old 28th April 2010, 04:14 PM   #21
Koifarm is offline Koifarm  Netherlands
Koifarm's Avatar
I did some calculation without knowing the requested output impedance.
One of my favourit tubes Telefunken ECC85 is a good tube for the job.
Output voltage about 3 Vrms with 28 Ohm I/V resistor. Output impedance between 10 and 20K.
Ronny
Old 28th April 2010, 04:36 PM   #22
kevinkr's Avatar
Originally Posted by Miniwatt View Post
Google brought me here: I'm looking for a new output stage for my TDA1541. I'm using a 28 Ohm I/v resistor with a 6211 SRPP. I am deeply in love with the sound but seriously lack gain. The 6211 is extremely microphonic btw. I was looking for tubes with a mu of around 100 and the 6N2P seemed a good candidate. After reading this the D3a seems a better choice, but I haven't made up my mind yet
Source impedance with an SRPP using tubes with high rp will be excessively high. Depending on implementation the impedance could approach almost half of the tube's rp, but typically will be at least 20% of it. A mu follower would give you both more gain (maybe up to 6dB more) and a much lower output impedance. High transconductance types like the D3A are your friend because of their low rp - crank lots of current through them..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 28th April 2010, 05:00 PM   #23
toufu is offline toufu  United States
I built the Lampizator using Oliver's board, and I did try 12AX7 as well as 6N2P, I have a pair of old Baldwin tubes and it sounds really good. I used Rk of 300 which is a bit low. The only thing is that it has a lot of gain.
Old 28th April 2010, 08:45 PM   #24
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I use a 12AU7 with 1k2 resistors.
It sounds very clean.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 28th April 2010, 09:35 PM   #25
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
I'd say forget the 12AX7 SRPP for this application, forget a mu-follower using the same valve as well.
A D3A based circuit is much, much better if you can source the valve.
Other than that, and I haven't really looked into it, an Aikido topology using a valve with a mu of 40 (a la E80CC, 6085) could be a tempting alternative perhaps.
Frank
Old 29th April 2010, 05:14 PM   #26
Miniwatt is offline Miniwatt  Netherlands
Miniwatt's Avatar
@ koifarm: thanks for the circuit!
I can get some D3a's, and I wonder why fdegrove is so convinced this is the way to go.
Old 30th April 2010, 12:59 AM   #27
fdegrove's Avatar
Very low noise, pentode with high perveance, low Zout.
Just about the ticket, no?
Frank
12ax7 srpp dac outputHide this!Advertise here!
Lowering gain in 12AX7 SRPP preamp net-david Tubes / Valves 27 3rd August 2015 11:11 PM
SRPP with FETS, what output stage? davidallancole Solid State 18 4th January 2008 05:39 PM
SRPP decoupling cap vs. output transformer matejS Tubes / Valves 4 30th July 2007 10:59 PM
How to figure output Z of SRPP? smbrown Tubes / Valves 13 12th January 2007 03:15 PM
6as7 SRPP output stage Molloy Tubes / Valves 4 15th September 2006 05:39 PM
