Resistor before tube rectifier
Old 14th November 2008, 05:23 AM   #1
habsrock93 is offline habsrock93  Canada
Default Resistor before tube rectifier
I'm in the process of throwing this power supply together http://www.diyaudio.de/archive/dac2.pdf ( just grabbing parts from my misc. box ), but I'm not confident in what wattage those 47 ohm resistors should be. I have 3watt resistors... Any help would be appreciated
Dave
Old 14th November 2008, 06:38 AM   #2
And just to help my understanding a bit... Are those 47 ohm resistors there just to provide voltage drop, or do they serve another purpose? I really need a book on this stuff
Dave
Old 14th November 2008, 06:49 AM   #3
DigitalJunkie is offline DigitalJunkie  United States
Send a message via AIM to DigitalJunkie
Scroll down.
Old 14th November 2008, 06:57 AM   #4
SpreadSpectrum is offline SpreadSpectrum  United States
SpreadSpectrum's Avatar
Man, somebody saw my previous post before I deleted it...
They appear to be for current limiting. Tube rectifiers don't like too much peak current.
You can calculate the required power rating. Just look at the ECC82 data sheet. You know the plate voltage(260V). You know the grid voltage (-9). Find the current draw from each half from the plate characteristics. Ohms law and P=IV will get you the rest. Don't forget that this current is divided over two resistors.
Look at the data sheet here
Old 14th November 2008, 07:55 AM   #5
laughingboy is offline laughingboy  China
Hi, habsrock93,
Do you talk about the resistors just connected to EZ80? 47ohm /3 watts is enough to meet any working condition of the tube there,
best regards, laughingboy
Resistor before tube rectifierHide this!Advertise here!
tube rectifier bonsai171 Tubes / Valves 37 12th March 2005 08:07 PM
Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? zxx123 Tubes / Valves 4 21st February 2005 05:02 AM
Tube rectifier for VDIGC tube psu ebijma Chip Amps 2 11th March 2004 05:02 PM
Tube rectifier ?s Tim Wyatt Tubes / Valves 16 10th March 2004 08:03 AM
