TCJ Push-Pull calculator v2
Old 14th November 2008, 02:33 AM   #1
SpreadSpectrum is offline SpreadSpectrum  United States
SpreadSpectrum's Avatar
Default TCJ Push-Pull calculator v2
I was considering purchasing TCJ Push-Pull calculator version 2, but the website has a bunch of broken links where the product information should be. I get no response from the support email address. I would like to have a tool to automate calculations, but don't want to gamble with my hard earned money.
Anyone own this and is willing to share what it does so that I can decide if it is worth buying? Screenshots would be appreciated.
Old 14th November 2008, 04:41 AM   #2
DougL is offline DougL  United States
I use it. Very easy to use. Would it be more approprate to email you some screen shots?
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 14th November 2008, 05:10 AM   #3
That'd be great. I'm particularly interested in which tubes it has curves for. Also, I'm hoping it does on the fly calculations for power output and you can drag load lines around and print things out and all kinds of cool things like that.
Thanks in advance.
Old 15th November 2008, 01:50 AM   #4
Here is a results screen
Old 15th November 2008, 01:52 AM   #5
Here is most of the sine wave voltage
Old 15th November 2008, 01:59 AM   #6
There are 57 tube types from 6h30 to 45 and SV811-10 to 6B4 and 6SN7
Here are the Curves
I am runing into forum max file sizes. So I am only showing a portion of the screens
Old 15th November 2008, 02:03 AM   #7
Here is the results file
Old 15th November 2008, 06:37 AM   #8
Well, it looks handy and doesn't cost too much, maybe I'll pick it up.
Thanks for taking the time to post the screenshots.
Old 15th November 2008, 07:24 AM   #9
jammer55 is online now jammer55  United States
You can also add user defined triodes or triode connected pentode/tetrodes to the database.
Old 13th February 2009, 08:28 AM   #10
dsavitsk is offline dsavitsk  United States
dsavitsk's Avatar
I just downloaded this. I have been skeptical about its usefulness for some unknown reason, and indeed, there is a lot that it doesn't do -- no pentode or ultra-linear circuits, no ultrapath caps, no just drawing a schematic and getting an analysis. However, I've learned more about push-pull amps in the last two hours just by tinkering around with some circuits than in months, ne years, of books and online reading.
Worth $100? perhaps, but easily worth $30. Most important lesson thus far -- there is just not that much power to be drawn out of a pair of Class-A 2A3's ...
TCJ Push-Pull calculator v2Hide this!Advertise here!
push-pull PWM IC chimi Power Supplies 19 4th September 2008 09:32 AM
Any TCJ Push-Pull Calculator users? aletheian Tubes / Valves 1 25th July 2006 05:30 AM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
push pull 845 audioman Tubes / Valves 5 30th August 2003 05:53 PM
Double push-pull versus single push-pull jraraujo Tubes / Valves 19 19th October 2002 12:23 AM
