#431 |
I scavenged a big heatsink out of an industrial motor inverter and just mounted some TO-220 thick film resistors to it. Then I made a 1K stepped attenuator and put it in parallel with the load along with some diodes to clip the output if it gets too high. Then I ran that to a soundcard. Cheap and simple.
The inverter had fans on it, too which I mated to an old laptop power supply. It's probably good for 100+W I figure. As for the VR tube, you want to be running it on the hot side because your load will never decrease from the quiescent value(and it looks cooler ), but it will increase with grid current. I would expect it to dim when you draw grid current(since more current is going into the power supply's load), but I would make sure it is not going out. That might cause problems. I had to solder the mosfet source and source resistor directly to the socket in order to keep oscillations away on my AB2 KT88 amp. I probably should have mentioned that to you earlier. It pays to minimize lead inductances if you are going to forgo a grid stopper (which is necessary for low distortion AB2). |
#432 |
Here is a snap of the square wave before fixing the oscillation. I think tnis one was at around 1kHz.
![]() Uploaded with ImageShack.us Here is a sine wave with the oscillation (now fixed): ![]() Uploaded with ImageShack.us Here is the output from each phase of the input stage: ![]() Uploaded with ImageShack.us Here is the same inputs (each phase of the input stage) with the 'sum' function of the scope, with the same scale. Note a little distortion: ![]() Uploaded with ImageShack.us If there are any tests I can do with the limited equipment available, I am happy post the results for you. Cheers, Chris |
#433 |
Lets see some squarewave pics at 1kHz, 2kHz, and 10kHz at 1Watt with the osc corrected. Have you calculated / measured open loop gain? You can also use ferrite beads per George's recomendation to stomp out oscillations when grid stopper are troublesome, as in AB2.
I am just now getting audiotester to work well enough. Using Pete Millett's sound interface REALLY helps, but you can get some close measurements without it as long as you are carefull of the soundcard. Or are you using a MAC? In my OPUS I also saw some tilt on the squarewave, initially. It is a low frequency roll off issue. Part of my problem was the input cap was to small for the impedance. I also lowered the impedance of the RC decoupling on my bias circuit. I don't think you have the later. Even still, I have a hint as seen in the attached photo.
Living Life Doing the Waltz in 4/4 meter. Last edited by SGregory; 24th April 2010 at 01:51 AM. |
#434 |
OK, so for the oscillation, try to shorten the leads as much as possible, and use as small a resistor that works? Re-locating the MOSFETs would require a lot of re-work.
As for soundcard, I am using a Macbook Pro on the desktop and the Mac Mini as the HTPC. Nothing I can put a soundcard on... Mods may have to wait a few days. Have a licence renewal exam Monday then away with work till Friday. Thanks for the help and input. Chris |
#435 |
I really like that thing. However, I built a 1M input impedance version, so I get better noise performance coming straight off the stepped attenuator on my dummy load for amp output testing. I love being able to use 100X scope probes for measuring distortion on CCS loaded stages swinging a lot of volts. It is awesome to be able to probe that without loading it down and causing a bunch of distortion.
#436 |
Chrish,
Maybe you may have an unknowing freind who would be able to loan you a x86 machine to play with. ;-) Spread, I am thinking about building a second interface, perhaps I will try your mod.
Living Life Doing the Waltz in 4/4 meter. |
#437 |
A quick update...
Well, as for the oscillation, I tried just about everything. I tried placing the MOSFEt right next to the output tube with a very short lead, I tried 100R plate resistors, then with the air core inductor wound around the resistor. I tried grid stoppers and ferrites, all to no avail. In the end I noticed that the oscillation changed when I touched my signal generator. I have a BNC T junction on my battery powered signal generator. One connection to the scope, the other to the input RCA of the amp. I removed the T connector and tried just connecting the signal generator directly to the amp and using a scope probe at the grid of the first stage to detect input signal. Oscillation gone. I removed all the stoppers and left the MOSFET close to the output tube. Appears to working OK now. Now, some questions. I have re-read the thread a few times and always pick up some good advice that I did not see or was too ignorant to understand. I used Tubelabs recommended procedure for setting up: Set current on first stage to get 160 volts at the plates, set current on second stage to get best signal (highest amplitude clean waveform) on the scope at about 320 volts. Drive at the output of the MOSFETs is around 150 volts P-P. All appears to be OK. The current for each of the tails in the diff amps is 8mA. That is 4mA per triode section. When I look at the anode resistors value, that looks to be about right for the design. My question is that I have read (MJ in Valve Amplifiers) that the 6SN7 is most linear in the 7-8mA range. Clearly, to get that current through the tubes, I am going to have to halve the value of the anode resistors. Is this required with the 6SN7 diff amp? The current values for the anode resistors are those recommended by Tubelab. Past experience is that setups recommended by Tubelab are usually for a reason. I am sure there is one here that I have missed or too dumb to understand Unfortunately my test equipment does extend to being able to do sophisticated distortion measurements.Tubelab also mentioned adjusting the grid of the second triode in the first stage to help correct some DC offset. Not quite sure what this is describing. I suspect it might be similar (or the same) effect I noticed of having a small difference in the plate voltages of the first stage turn in to a large difference in the second stage. I trimmed the plate resistors within a couple of tenths of a percent of each other - still got the same effect. I have a whole bunch of Russian 6SN6 equivalents, so subbed in tubes until I got one two that gave identical plate voltages. Unfortunately I don't have well matched pairs of my "good" 6SN6s, so interested in implementing Tubelab's suggested circuit (or similar). As for how does it sound, not sure yet. My main system is bi-amped with an active crossover. I have a Baby Huey doing duty for the mid range and an SE 6P15P for the tweeters. The new amp has a greater gain than the Baby Huey, so a direct replacement is not possible without a whole lot of re-tweeking the setup of the active crossover. Don't want to do that until I have sorted the big issues of the amp. Also will need it in the workshop as the model for the second mono-block. Thanks Guys! Chris |
#438 | |||
If I remember correctly I was running 7403's at about 500 volts last time I had it running. Higher B+ voltage will produce more current with a given resistor value. It is also possible that I have changed the resistors since the schematic was drawn. Since about 1200 miles seperate me from the amp and my notes I really don't know right now. From my experiments the 6SN7 has a fairly wide sweet spot (current and voltage where it works good) but I do tend to favor highish currents. In my circuits where the tube is CCS loaded I tend to run the current rather high, high enough where you have to consider the total tube dissipation. In this case the tube is resistively loaded so reducing the plate load resistor will reduce the gain a bit. There is a trade off between gain, drive voltage ability, and distortion. I was playing with tubes that required considerably more drive voltage than the 6L6GC, so my "optimum values" may not be the same as yours. It is more likely than not that I would change the resistor values as needed once I settled on the final output tube choices, power output level and B+ voltage. After the amp is running I use an FFT analyzer, and listening tests to tweak parts values for optimum sound. Quote:
Good luck with your amp. I hope to get back to mine in the not too distant future. As with all projects I have come up with a dozen new ideas to try with this amp, but they involve Pentode wired sweep tubes and local negative feedback for big power output (ideas learned from playing with the red board). So far I would leave it just like it is for 6L6GC's and reasonable power levels, with some parts value tweaking as needed. Quote:
Too much power is almost enough! Turn it up till it explodes - then back up just a little. Last edited by tubelab.com; 7th May 2010 at 11:43 PM. |
#439 |
Thanks again Tubelab, really appreciate the advice and assistance. I have learned quite a bit on this long process thanks to you and others! Regarding your balance control, I am guessing that using the regulated + and - supplies for the MOSFET followers will work? You say +/- 1 volt, so I am thinking of using a couple of zeners on the previously mentioned +/- supplies to give this, with appropriate current limiting resistors to give a milliamp or so of current? I will draw up a small schemo this afternoon.
As for computer for sound distortion measurements, I do have a 10" netbook computer that runs XP (Asus eee PC 1000H). Perhaps I can find some software that will be useful with this as it is conveniently small for my workbench. Thanks again! Chris |
#440 | ||
I use Win Audio MLS software which is not cheap. Many forum members use Audiotester or RightMark. I am sure that there are others out there. Once you find software, run this test. Before trusting any measurements connect the PC's output right back to its input. Run distortion and frequency response tests. This is your measurement threshold. You will be able to accurately judge equipment that is at least 10 times worse than these measurements. This sounds bad, but my old computer measured something like 0.02% distortion and the frequency response was within a tenth of a db or so from 10 Hz to 40 KHz. Find me a tube amp that can do this! Unfortunately that computer died and I haven't built a new one yet.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
| Red Hot 6L6GC | oldmanStrat | Tubes / Valves | 26 | 29th May 2009 12:53 AM |
| Need help with 6l6GC choices | BlackUnikorn | Tubes / Valves | 19 | 5th August 2008 01:39 PM |
| 6l6gc SET, my first DIY | alexmoose | Tubes / Valves | 3 | 27th April 2006 03:00 AM |
