6L6GC AB2 Amp - Page 32 - diyAudio
Old 26th July 2009, 03:32 PM   #311
Tubelab_com's Avatar
I also see one of those huge ACS caps. I got 6, I'm still wondering how I'm going to safley mount them in any "regular" sized chassis.
I usually mount motor run caps with the band clamps made for mounting big elecrtolytic cans of similar size. That would leave a big ugly threaded stud sticking out of the top of the cap. I have 6 of these caps too. I may try to cut the stud off of one, but I doubt that would turn out good. My other thought is to look for something that would thread on to the stud that doesn't look ugly. Check out one of the stores that caters to the import car tuner crowd.
In this case I have 3 big ugly toroids to hide. The ASC cap is starting to look good!
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 26th July 2009, 04:26 PM   #312
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
Get yourself a nice chrome-plated grapefruit shooter for it. How about a wing nut. I've got 9 of those caps on the way. I bought 6, but then I noticed the deal was buy two and get one free...LOL.
My mind is still rather boggled by the amount of power you are getting out of a pair of 6L6 tubes. I guess I never really looked at what was possible in class B, since I've never seen it done well until now. Then again, I've never had a MOSFET in a tube amp until a few months ago....
Old 26th July 2009, 04:30 PM   #313
Alastair E's Avatar
Originally posted by tubelab.com
I put a pair of IRF 820's in the amp. One blew instantly, and the other lasted until I turned up the drive.
Most mosfets have internal zener diodes to keep the gate voltage from going high enough to blow the oxide. These fets do not have the diode, so the gate got blown in both of them. It may be possible to add an external diode.
I spent all day tweaking on this amp. It positively rocks now. It is late now. so I will report further tomorrow morning.
A few years ago, i was experimenting with the powerdrive and using IRF 820 Mosfets....
All was well, until I turned the wick up then one went short, The 811A on that half of the P-P didnt like it much--Its grid glowed a loverly brightness, hotter than the heater,-amazingly it survived!
I think what happened, was the drive voltage to the MOSFET exceeded the supply To the fet by the Gate/Source breakdown volts, and 'punched-through', killing the fet (I was using a 150V supply to the MOSFET Follower stage in that bread-board as I recall
Anyway, my 'Cure' was to add a zener, a small 250mW one between the Source and Gate. I used a 12V one, and mounted it directly on the pins of the fet.
--I used a 100K 'Gate-Stopper' and connected everything to the gate through that....
Worked well and its what I use when using MOSFETS as followers ever since.....
--Thanks George for sharing all your exploits, I always look out for your posts here, They are a great inspiration,--You'll be extracting 100 watts outta a 12AT7 next!
Das Beste Oder Nichts
Old 26th July 2009, 04:39 PM   #314
Michael Koster's Avatar
Chrome-dome lug nuts! The inside threads can be oversize. Actually,
you can probably find chrome plated cap nuts of the proper size at
a good hardware store. Another thought was to make a cool looking
plate out of lexan or aluminum to bolt on top of these when mounted
in the usual way. This might look really cool with more than 2 caps in
a nice geometric design. Maybe you could fashion a clever "hat" for
them. A knit cap is what I always used to hide an ugly haircut ;-)
I'll bet Geoff Kait could come up with a clever lil something or other
that would improve the sound at the same time!
I just picked up a bunch of 40/600VAC CDE caps with the mounting
studs for a big voltage doubler project. I decided to build an enclosed
chassis with exposed wiring on top since I have these output tubes
with external anodes anyway. I'm just going to bolt them through
the top plate, terminals up. But, another option is to mount them
below deck horizontally, perhaps bolted through the back plate.
I would connect a bleeder resistor permanently to each one before
applying voltage to them.
Michael
PS Oohh, how about a toroidal terminal like on a tesla coil...
Old 26th July 2009, 08:19 PM   #315
agent.5 is offline agent.5  United States
I had been saving the Plitrons for "something special". Could this be it? I had been thinking that I wanted something that could really use up some of the 400 watt at 20Hz rating that these transformers carry, but is that realistic? Would I actually use a 1KW tube amp? It would be cool, the ultimate bragging rights, but with the heat is south Florida, I couldn't turn it on for more than 5 minutes. That is about how long it would take to eat my speakers too!
Well, I think you can make a dual channel amp with switches for triode and pentode mode, high and low power. Just like a Rivera TBR-5. Put it inside a 4U (maybe 6U with the Plitron and ASC caps) chassis and tour the World with a Fender guitar.
http://www.youtube.com/watch?v=W85g0XyTqyE
Old 27th July 2009, 12:15 AM   #316
was the drive voltage to the MOSFET exceeded the supply ....Anyway, my 'Cure' was to add a zener, a small 250mW one between the Source and Gate.
I think this is how I blasted the IRF820's. One of them blew when I switched ranged on the audio generator. I had found a package that originally had 5 parts in it. 3 were left. I just blew up 2 of them. I vaguely remember blasting the first two in the same manner a few years ago. That is when I started using the Toshiba parts since they have the zener diodes built into them. I would try the 820's again except I inly have one left. I will get some more and some 10 or 12 volt zeners next time I order parts. I have been using 1 K ohm gate stoppers with the Toshiba parts. So far I have killed one of them and it happened when the ground lead on my scope probe landed in a live board yesterday.
Nah, 12AT7's are a useful tube. I have several hundred 12AU7's how many do I need to hook together to make 100 watts?
Whatever I build, its main use will be for HiFi. Arthritis and stiffnes has limited my guitar playing lately. I am still waffling about the tube and power output choices, and a few more experiments are in order, but I really liked what I heard last night, so that may be the amp design if I don't come up with something better by the time I am finished with the Tubelab SE I am building now.
I have never found a pentode amp that I really liked the sound of. I have always preferred triode for sound and UL for power. These transformers do not have UL taps, ans I am getting plenty of power in triode, so I see no reason to use pentode. I am thinking about adding a class A mode switch that will limit the power to maybe 30 WPC. I have to experiment with using a really big CCS in the cathodes of the output tubes to make the amplifier fully differential. This will force class A operation, and reduce power output, but I think that it may improve the sound. If I need more power, I can add more tubes, or use bigger tubes!
There is no class B here. This amp runs in AB2 mode. True class B runs at zero idle current. That usually offers up tons of crossover distortion, so some idle current is used. Most conventional tubes don't do well in class B but there are tubes designed specifically for class B operation. Screen driven sweep tubes do work well in class B operation but this thread was all about class AB2, and the 6L6GC so that is where I started. I just happen to have 7 EH KT88's and 1 EH 6550 (same tube) and I like the sound of them more so I have been swapping back and forth. I have some EH EL34's too, so they will get tested sooner or later.
AB2 does allow for some added power output over what is found in AB1. This is clearly stated in the vacuum tube data books that go back to the 1930's. The problem was thay didn't have good drivers that could work into the extreme changes in grid impedance seen in AB2 mode with low distortion in the 1930's.
Check out the screen shot from the data sheet for the RCA 45 tube. Yes, a pair of those little guys were rated to put out 18 watts in AB2. No, I haven't tried it yet. RCA rates the 807 which is a 6L6GB at up to 120 watts for a pair in AB2.
Old 27th July 2009, 12:59 AM   #317
rknize's Avatar
Right...AB2...more "B" than is usually possible anyway.
I'd hate to try it with a 45...but I have like 10 pairs now, so....
Old 27th July 2009, 02:48 AM   #318
vinylkid58's Avatar
18 would do it, but 20 would be safer. You could do mono-blocks, and call them the Tubelab Twenties.
My old PP EL84 pentode amp sounds pretty good for a simple circuit. Not quite as good in the bass region as big trioded tubes, the OPT's are rather small.
Jeff
Old 27th July 2009, 03:52 AM   #319
I have a few 45's that I have collected over the years. Most are well used and not "grade A" quality. I did some experimenting with A2 operation in the Tubelab SE and found that many tubes that work fine in a low powered amp simply do not have enough emission left in their old filaments to take advantage of A2 or AB2 mode. If every electron leaving the filament makes it to the plate with a slightly negative grid voltage pushing the grid positive will not increase plate current. In fact the plate current may actually decrease because some of the electrons were diverted to the grid. Measurements on several old 45's seem to support this theory.
I have found that tubes with plenty of reserve emission capability make good canidates for A2 or AB2 operation. There can be too much of a good thing though. I have yet to get good AB2 operation with some of the monster sweep tubes like the 6LW6. The emission capability of the cathode is so great that the control grid will draw several hundred milliamps with a small positive voltage. This lead to a tube arc yesterday which is a very bad thing when you have that monster ASC cap feeding the fire.
Since it was an easy experiment I connected the KT88's in pentode mode. As expected I got more power. Full tilt with the power supply dialed up tp 475 volts is 130+ watts. I only had one power supply accessible at the time so the screens are connected to 475 volts as well. I noticed some screen glow whenever the power meter was above 100 watts. I connected the DVD player and speakers and applied some Depeche Mode. The bass was far "looser" than triode mode but could probably be cleaned up with some feedback. Could enough feedback be applied to clean up the bass without sucking the life out of the sound? I don't know yet.
The distortion measurements were quite a bit higher than triode mode too:
2500 ohm load pentode mode
THD at 1 watt 0.50%
5 watts 1.13%
10 watts 1.71%
20 watts 2.60%
40 watts 3.95%
60 watts 4.7%
80 watts 4.97%
100 watts 4.41%
120 watts 4.03%
130 watts 5%
OK, would that sound as bad as one big 12AU7 or 20 times worse? Seriously, it has been stated multiple times by several people on this forum that all 12AU7's suck. I have not yet formed my own opinion on that, but it's for a different thread at a different time. When I have time I will have no problem melting a few of them in the name of science.
On the other hand most agree that the 6SN7 is a good sounding tube. The tubes in this amp sure do sound nice. Could it be that one with the red base that is giving this amp its magic sound?
Old 27th July 2009, 04:07 AM   #320
vinylkid58's Avatar
My little amp has local feedback only.
And some other forums as well. Some of them really do stink, but some don't sound too bad.
Jeff
Red Hot 6L6GC oldmanStrat Tubes / Valves 26 29th May 2009 01:53 AM
Need help with 6l6GC choices BlackUnikorn Tubes / Valves 19 5th August 2008 02:39 PM
6l6gc SET, my first DIY alexmoose Tubes / Valves 3 27th April 2006 04:00 AM
Copyright 1999-2017 diyAudio
