6L6GC AB2 Amp
6L6GC AB2 Amp
Old 13th November 2008, 06:18 PM   #21
kenpeter is offline kenpeter  United States
With reasonable power supply voltage, its possible to run your
chosen tubes to full power without need for driving G1 into A2.
Not sure what A2 here buys you, but an added complication?
I don't think A2 is necessarily a bad thing for Triodes and some
Pentodes. Especially when run at lower than "normal" voltage,
and you might want more current without increasing voltage.
But I'm not too sure its a great thing for Beam Power tubes?
Alignment of G2 to the shadow of positive G1, may mean G2
now sits where G1 could FOCUS those beams directly onto it.
I don't know if it works like that IRL, it just worries me...
Don't imagine a problem if you space charge the tube with a
positive G1. As long as G2 remains always negative, as this
mode could repel the offending focused beams safely away.
1W of acceleration at G1 can effectively replace several watts
at G2. By effective, I mean for the same plate current.
Do real space charge tetrodes deliberately misalign G2? With
an intent that G1's shadow will focus differently when driven
positive?
I think I'd rather have an unaligned Pentode than a Beamer
if both are grids are intentionally going to be driven positive,
even if only at the music peaks.
Old 13th November 2008, 07:04 PM   #22
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
6L6GC's give plenty of power in AB1, because you can crank the VG2...
If you're bent on AB2, I'd go with 807's... at least they look nice
They're basically a 6L6GB, higher Va rating, nice ST bottle, cheap, even US ones... the war office had them churning out tons of them during WWII... korea too, and some antiques were probably still running 'em in vietnam.
They don't need too much drive.. AB2 something like
Va = 600
Vg2 = 300
Rl = 6k
should do ~80W at ~3% THD without any NFB, iirc... which you can add of course...
Old 14th November 2008, 02:06 AM   #23
Eli Duttman is offline Eli Duttman  United States
Man oh man, does the Tamura F-684 look SWEET. That "iron" would KILL in an all out "El Cheapo Grande". I am positively GREEN with envy!
Let's stick with the 6L6GC. A 450 V. B+ rail will be very comfortable for UL mode "finals". 100 Ohm Carbon film resistors right at the g2 socket lugs do double duty as stoppers and current limiters.
Eli D.
Old 14th November 2008, 02:17 AM   #24
SpreadSpectrum is offline SpreadSpectrum  United States
SpreadSpectrum's Avatar
McIntosh ran their amps in AB2 but avoided crossover distortion through the use of a very complex bifiliar wound transformer...
This didn't have really anything to do with the amp being AB2 or AB1 but that it was a unity coupled design. Because it was unity coupled, they were able to run much lower quiescent currents without too much crossover distortion.
Class AB2 is a lot closer to class B, especially on strong peaks, then it is to A.
Any amp (AB1 or AB2) is closer to class B when one tube cuts off. In fact, it has actually arrived there at that moment.
clipping is also greater in class AB2 operation then class AB
Sorry, a well designed AB2 driver softens clipping at the onset of grid current substantially and eliminates blocking distortion.
I have a KT88 amp on my bench right now that has a source follower directly coupled to the grid. It is triode connected with a B+ of 450V and a quiescent current of 50mA. I currently have 1k grid stoppers on the KT88s. All I need to do is remove the 1k resistor and bridge it with a wire and I have an AB2 amp. Am I to understand that at the moment that I make the swap I will suddenly start generating crossover distortion? Why would that happen? I haven't altered the quiescent operating point at all, just increased headroom.
Actually, I've listened to music with this amp at full throttle and it sounds surprisingly good even when clipping grossly. Not good, mind you, but not nearly as bad as the scope traces seemed to indicate it should.
Just look at 6l6 positive grid curves. There is nothing ugly there. It is just harder to get there.
Old 14th November 2008, 03:25 AM   #25
weinstro is offline weinstro  United States
weinstro's Avatar
Originally posted by SY
Nowadays, even us old die-hard tube guys have to admit that a source follower does better. I've been using them in AB2 drive without seeing anything like crossover distortion. And likewise, I've used them in screen drive, which is even more demanding of the driver.
The advantage of a follower over a transformer, besides bandwidth and lower source impedance and distortion is that it's not a stepdown. This reduces the distortion of the driving stage. It's a win-win.
Sy, and all the others: Thanks for the clarifications on this topic.
So please tell, what are the design considerations when dropping in a MOSFET source follower before the output tube? What parameter minimums and maximums should I be looking for?
Also, although I realize it's not a true 6L6, but would a source follower work in a Williamson topology?
Thanks!!
Old 14th November 2008, 03:28 AM   #26
On Hiatus
SY's Avatar
6L6GC AB2 Amp
In what way? Let's consider a 6L6. Looking at the GE datasheet, for AB1, 360V on the plate, 270V on the screen, the plate to plate load is 3k8, idle current is 88mA. For AB2, same voltages, same plate load, the idle current is... 88mA. So the cutoff of each side is at the same point, regardless of whether or not you take the already-turned-on side into grid current on peaks. The only difference is the max current, which is irrelevant to anything involving crossover or notch distortion.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 14th November 2008, 03:31 AM   #27
On Hiatus
SY's Avatar
6L6GC AB2 Amp
Rob, I just use an IRF820 with a +/-200V supply in a plain vanilla source follower configuration. 10mA idle current. I've tried fancier circuits like cascodes, but found no real advantage. The device that Eli suggested should work even better, I just haven't used it, and to be honest, the source follower isn't the weak link in my amp anyway.
Old 14th November 2008, 03:47 AM   #28
chrish is offline chrish  Australia
chrish's Avatar
Wow!
I am glad that there is so much interest being generated! I must admit, much is going over my head...
Yes Eli, those transformers look sweet! I picked them up one day when my self control was not that great Since that happened, I have purchased an apartment with my partner and now have a mortgage... The other thing is that now I have to be a little 'low key' with my purchases. This is why I want to make sure I have a pretty good idea what spec we are talking about so I can start looking at sourcing the power iron. With economies around the world going down, Australian dollar fluctuating, the industry I am in being reliant on discretionary spending etc I have to be a little more cautious and careful with spending. Also have to answer to my 'better half' now
So, are we talking el-cheapo grande, or as discussed above with AT7 driver, ECC99 LTP and mosfet source follower (or are they the same thing!).
This is getting interesting! looking forward to getting in to the books and getting the soldering iron and scope out of storage!
Chris
Old 14th November 2008, 04:32 AM   #29
HollowState is offline HollowState  United States
HollowState's Avatar
Yes, that was exactky my point. Glad you agree.
I was refering to clipping originating at the output stage. Not clipping caused by the driver. Please see the diagram below.
At first I was scratching my head over this. How could simply bridging the stoppers move the output class to AB2 without changing the quiescent operating point? Then it occurred to me that perhaps we are talking about two different things. Correct me if I'm wrong here. You're referring to allowing AB2 operation (grid current) to happen in an AB biased stage by way of a strong supporting driver stage. I was referring to a leanly biased output stage to allow higher plate efficiency. This was also called AB2 since it was closer to B. Since I learned this stuff many years ago I may have melded the terms somewhat.
Victor
There cannot, and never will be, any progress in society, vis-a-vis racism, so long as the concept of celebrating Diversity -- in it's current, politically-correct, deliberate, punitively extractive form -- continues.
Old 14th November 2008, 05:01 AM   #30
Victor,
I think we are speaking the same language now.
Am I mistaken in thinking that given a perfect driver, clipping shouldn't occur until Vg = Vp, which is when the grid would swallow up all electrons from the cathode? Is that what the diagram is depicting?
Edit:
Sorry, just looked at the figure again and it seems that it is clipping at Vg = 0. Maybe this guy needs a source follower.
6L6GC AB2 AmpHide this!Advertise here!
Red Hot 6L6GC oldmanStrat Tubes / Valves 26 29th May 2009 12:53 AM
Need help with 6l6GC choices BlackUnikorn Tubes / Valves 19 5th August 2008 01:39 PM
6l6gc SET, my first DIY alexmoose Tubes / Valves 3 27th April 2006 03:00 AM
