EL95 SE schematic wanted
Old 12th November 2008, 06:05 AM   #11
mitwrong is offline mitwrong  China
mitwrong's Avatar
Send a message via AIM to mitwrong Send a message via MSN to mitwrong Send a message via Yahoo to mitwrong
Default Why one channel use one more tube
Originally posted by planet10
Here is a grundig EL95 SE schema (with a common PP woofer channel)
I read the schematic, why the upper channel use one more tube than the lower, would this cause 180 degree out of phase between L /R channel, need to alter the red / black spk. wire in either one channel.
Old 12th November 2008, 08:06 AM   #12
Yvesm is offline Yvesm  France
Yvesm's Avatar
Default Re: Why one channel use one more tube
Very curious indeed !
There are 3 output transformers, one per channel for trebble and one common for basses.
The EL95 are used in SE mode for stereo/trebble channels and in PP for mono/basses amplification.
The additionnal unity gain stage is a paraphase/see-saw phase splitter needed for the PP mode to work while the correct phase for stereo/trebble is restored by swapping the connection at the secondary of the transformer (black/green wires) in the -so called- right channel.
Predicting the crossover behaviour looks like a nightmare involving transformers caracteristics, caps accross them and separates feed back loops
Not so stupid for a bean counting/industrial point of view
Yves.
Old 12th November 2008, 12:15 PM   #13
mitwrong's Avatar
Default wiring colour system
Yves:
Thanks for Ur info.,another thing make me confuse, which is is there any standard or format that define the wire colour for what purpose, for instance green colour for right channel, yellow for left,----- etc.
is there any info. about this ? Thanks
Old 12th November 2008, 07:28 PM   #14
Franz Gysi is offline Franz Gysi  Switzerland
Franz Gysi's Avatar
Here what I built some years ago:
A classical very simple circuit, sorry, just handdrawn.
The result looked like this:
As you can see, I replaced the ECC82 by an E80CC, this is a very very fine driver tube for this application!
Backside:
Franz
Old 12th November 2008, 07:37 PM   #15
Yvesm's Avatar
So cute !
The driver is larger than the output tubes ! !
What about a 6J6, just for the look ?
Yves.
Old 12th November 2008, 07:47 PM   #16
Franz Gysi's Avatar
Cute? Thanks!
This how it looked inside:
I used two torroid trannies: one to step down to 24VAC, the second one to step up.
The first one had some added windings (black wire) for the heaters of the tubes.
Most of the enclosure is filled with psu parts. Two output trannies from an old SABA radio.
The smallest part of the space is used for the amplifier circuit:
Franz
/Edit
I add a picture from the brainstorming phase from this project:
Old 12th November 2008, 09:31 PM   #17
azazello is offline azazello  Bulgaria
azazello's Avatar
1.55 ma is to low for good sound. Maybe it doesn't enought for
input capacitance of EL95 . Try to increase to 5 ma /put 50 kom aprox. in plate, and 600-1000 ohm in cathode of ECC82/. And put EL95 in triod mode!
Projects: OTL-OCL 6AS7 Gen. Electric, SEs 2A3 RCA, 300B JJ, 6S4S, 4P1L, EL11 Telefunken, 6AS7 RCA, 6S33S, 6S41S, 6S19P, E84L Siemens, E236L Telefunken, headphone ampl. OTL Loftin White 6AS7 RCA,... PPs 6005 Gen. Electric, EL34 Mullard, 6L6....
EL95 SE schematic wantedHide this!Advertise here!
Wanted Mordaunt-short MSW20 Schematic Wanted simon dart Subwoofers 0 22nd May 2009 09:19 AM
EL95 mini SE aurche Tubes / Valves 2 20th October 2008 04:56 PM
2A3 DRD schematic wanted Mas Penk Tubes / Valves 0 8th September 2005 02:46 PM
Copyright ©1999-2017 diyAudio
