Making component choices (6V6/EL84 PP)
Old 11th November 2008, 03:34 PM   #21
boywonder is offline boywonder  United States
boywonder's Avatar
Rockgarden: No pics posted above. A 275-0-275 V xfrmr should be fine, as I started out with too high B+ for EL84's (I was using ss rectification). What rectifier are you planning on using?
Old 12th November 2008, 02:54 AM   #22
rockgardenlove is offline rockgardenlove  United States
I'm not really sure yet...what's a good choice? I was thinking 5U4 GB.
Would SS rectification yield a punchier amp?
Cheers!
Old 12th November 2008, 04:51 PM   #23
boywonder's Avatar
There are folks here that swear by SS rectification, and others that swear at it.
There are lots of opinions here as to which sounds better, but I don't have one because all of my amps use SS rectification.
Do a search, you'll find lots of opinions. If you choose SS rectification, you'll drop less volts, and you can use very inexpensive diodes or splurge and use FREDs for like $1-2/ea. SS rectification yields an "instant on" B+ which may lead to cathode stripping of your tubes but many folks here don't consider that an issue for B+'s less than say 1KV. This can be another heated discussion on the forum. Tube rectification gives a soft start B+ which is a little easier on the tubes.
FRED's are soft recovery diodes, producing less switching spike noise than conventional SS diodes so in my opinion are worth it, but I'm still a newbie.
The best approach IMHO is to get yourself familiar with PSUDII and develop/model either a SS or tube rectified PS that has low ripple, no ringing, and the desired B+. If you want to use tube rectification, PSDUII will steer you clear of using too much capacitance for your chosen rectifier tube.
Old 13th November 2008, 03:09 AM   #24
chrish is offline chrish  Australia
chrish's Avatar
5U4 GB gives a very large voltage drop (around 50 volts from memory). It is also a directly heated rectifier, so it has a fast warm up time.
If you need more B+, maybe try a GZ34 (5AR4). Less voltage drop and slower warm up time.
Chris
Old 13th November 2008, 03:39 AM   #25
Ty_Bower is offline Ty_Bower  United States
Ty_Bower's Avatar
I'll second what Chris said about the 5U4. In my limited experience I prefer the 5AR4 for its slow start and lower voltage drop. I guess I might consider using a 5U4 if I needed a lot of current, say more than 200 mA or so.
Solid state rectifiers are cheap and easy to implement. Maybe consider throwing in a couple CL90 or CL80 inrush limiter devices to help soften the startup a bit.
Making component choices (6V6/EL84 PP)Hide this!Advertise here!
5W EL84 drive EL84 SE Audio_idiot Tubes / Valves 31 31st May 2012 09:38 PM
Need help making some choices on what to build rockgardenlove Tubes / Valves 12 7th November 2008 03:19 PM
tell me the best of three bad choices... chipco3434 Digital Source 10 23rd April 2004 10:09 AM
Home Theater Combo - choices choices smithsonga Multi-Way 1 2nd April 2003 06:11 AM
