Old 10th November 2008, 01:50 AM   #1
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Default Which socket for a 5Y3??
Perhaps a truely stupid question, which socket does a 5Y3 use?
Does it have just the four connections....I'm reading that it uses an octal socket as say a 6SL7 ....with no pins on the other four?
Does it use the four pin that the 300b, 2A3 uses? What other tubes fit the same socket........I've searched & searched........I can't find any reference for it!
___________________________________________Rick... ..
Old 10th November 2008, 01:56 AM   #2
HollowState's Avatar
A 5Y3 uses a regular octal socket just like a 6SN7 would. The difference is that the 5Y3 only uses four of the eight pins that would be available. Actually, the tube itself generally has five pins on it's base. One of the five (between the filaments) has no connection.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 11th November 2008, 04:41 PM   #3
kevinkr's Avatar
Hi Richard,
Franks has lots of data sheets that show the information you were looking for.. Yes it is an octal type, and typically only 5 of the 8 pins are installed, with only 4 being in actual use. Same pin out as 5AR4..
http://www.mif.pg.gda.pl/homepages/f...93/5/5Y3GT.pdf
"Extraordinary claims require extraordinary evidence." - Carl Sagan
8 Pin DIP Socket Help Needed KP11520 Chip Amps 15 25th August 2007 04:52 PM
Should I keep these capacitors on my IEC socket? bikehorn Power Supplies 5 2nd August 2007 04:54 PM
what rca socket do you think is best?? wuffer Parts 24 25th May 2006 11:35 PM
RCA socket without having to solder? reMC Parts 3 9th June 2005 06:34 AM
Op-Amp Socket justpoor Digital Source 3 8th March 2005 09:23 PM
Copyright ©1999-2013 diyAudio
