Need some help identifying which tubes are suitable - diyAudio
Old 9th November 2008, 08:41 PM   #1
onform is offline onform  United Kingdom
onform's Avatar
Default Need some help identifying which tubes are suitable
Hello
I'm looking to find or compile a list of all valves and variants which are the same as any 9 pin tube that has the same pin-out as the ecc88 with pin 9 not used and heater voltages of either 12.6V or 6.3V.
Being new to tube rolling I want to know which valves would be suitable but with all the different variants and codes it is a bit mind boggling
I know some of you guys in here are veritable valve encyclopaedias so if you guys in the know could help me out it would be greatly appreciated.
Even if you can point me in the right direction it would help me. I am trying to teach myself but am getting quite confused.
Matt
Old 9th November 2008, 09:03 PM   #2
dsavitsk's Avatar
6CG7
6FQ7
12FQ7
8416
6DJ8/6922/7308
Old 9th November 2008, 09:17 PM   #3
onform's Avatar
Thanks is that exhaustive ?? or is this a starting point?
Do all the ecc series tubes have the same heater voltages??
Old 9th November 2008, 10:32 PM   #4
That "E" in European type designations is indicative of "6" V. heaters.
The 6DJ8/ECC88 has an internal shield connected to pin 9. Russian "6" V. heater types with an identical pinout are the 6Н1П, 6Н2П, and 6Н30П. Western "6" V. types with an identical pinout are the 6CG7 and 6GM8/ECC86. The 7058 pins out identically to the 6DJ8, but it has a 12-14 V. automotive heater.
"6" V. types lacking the internal shield connected to pin 9, but otherwise identical in pinout, are the 6FQ7, the 6GU7, and the 6AX7. The "12" V. heater 12FQ7 also lacks an internal shield.
Do not assume the types I enumerated exhaust the possibilities.
Eli D.
Help identifying IC mtl777 Parts 4 17th May 2008 10:10 PM
Are these vintage vacuum tubes suitable..... 69CamaroSS396 Tubes / Valves 6 6th June 2007 09:36 AM
I need help Identifying these nblimfark Multi-Way 0 13th November 2006 03:27 AM
suitable ob drivers for low powered tubes mrthieme Full Range 3 6th July 2005 12:37 AM
Suitable regulated/filtered 4volt battery-valve power supply suitable for 6+ valves? Layberinthius Tubes / Valves 0 11th March 2004 09:49 PM
Copyright 1999-2017 diyAudio
