ECC88 heater overvoltage damage?
Old 9th November 2008, 08:30 AM   #1
bays_9a5tt is offline bays_9a5tt  Croatia
bays_9a5tt's Avatar
Default ECC88 heater overvoltage damage?
Hi all,
just did something stupid, hooking 12VDC instead of 6.3V to a pair of ECC88. It didn't last longer than a minute.
Tubes glow normally now, heaters draw ~300mA which is close to spec.
Since my project is in construction phase, I have no way of checking if they're OK or not.
Did I damage the heater/tube?
Old 9th November 2008, 10:54 AM   #2
ilimzn is offline ilimzn  Croatia
Probably not. In fact, if there was anode voltage, this sort of technique is sometimes used to 'rejuvenate' old tubes. In the end you will have to try and see, but you have good chances that all is well.
Old 9th November 2008, 10:55 AM   #3
audiousername is offline audiousername  Australia
audiousername's Avatar
If the heaters are still continuous and the heater isn't continuous with the cathode (as in, the heater-cathode insulation is still working), I wouldn't worry about it. Valves are quite robust devices, unlike the three legged fuses often used nowadays.
Jason
Old 9th November 2008, 02:35 PM   #4
bays_9a5tt's Avatar
thanks, there was no anode supply during the situation and there is no connection between heaters and other pins.
one more reason to love them
ECC88 heater overvoltage damage?Hide this!Advertise here!
how to wire 6.3VDC heater on a heater with center tap (12.6V series, 6.3V parallel)? jarthel Tubes / Valves 9 14th April 2012 05:36 PM
G2 overvoltage ?? puginfo Tubes / Valves 3 30th July 2009 03:18 AM
Overvoltage to LM4780 Mr Teal Chip Amps 18 20th February 2005 04:11 AM
LM3886 overvoltage xplod1236 Chip Amps 3 20th July 2004 03:08 AM
overvoltage in my DC-DC theChris Parts 7 13th November 2002 02:37 AM
