Want to Build my first Tube Amp - diyAudio
Old 7th November 2008, 07:40 PM   #1
Default Want to Build my firs Tube Amp
Hi guys, i want to build my first Pass Labs Amp and an tube amp, i just build and Chipamps and im very happy with the sound.
but i want to still learning and want to build some Simple amps SolidState/Passlab and an tube amp too.
Hope someone can recommend me some schematics to build. i will make the PCBs myself!
Thanks in advance
Jose
Old 7th November 2008, 11:07 PM   #2
malanga is offline malanga  United States
These tube amps are very simple, inexpensive and fun to build:
http://www.dogstar.dantimax.dk/tubestuf/miniblok.htm
http://www.dogstar.dantimax.dk/tubestuf/mnibl2-1.htm
The SET version is the first tube amp I built.
Old 8th November 2008, 12:15 AM   #3
I like point to point style wiring over circuit boards for tubes.
Old 9th November 2008, 04:56 AM   #4
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Default What to build??
Jose:
So what are you expecting to learn from building a tube amp?
The choices are truely endless, from the simple to the complex.
Perhaps you should start out with a straightforward Single ended two, maybe three stage tube amp. My choice would be a 2A3 single ended, tube rectifyed...not too spendy on the output transformers.
I'm still trying to find a manufacturer here (Mar del Plata) who will custom wind transformers......I dropped an E-mail at Kaizen Electronica, B.A.(Transformer makers) but haven't heard anything from them.
________________________________________________Ri ck.....
Old 9th November 2008, 10:34 AM   #5
kmaier is offline kmaier  United States
kmaier's Avatar
I'm also in the camp for a DHT SET amp, point-to-point wiring. Makes a nice project amp, can sound exceptional, with the right system setup. I tend to prefer the 45 in most cases, albeit 3dB less than the 2A3, but they can also be quieter with AC filaments (which I prefer).
Before making yet another recommendation, an idea on what your price point is would be helpful and what other equipment you plan to use this with. Before diving into the SET waters, the speakers you plan on using will have a lot to do with how compatible things well be. SETs typically favor higher sensitivity single full-range drivers which have a mild impedance curve and don't require a high damping factor to maintain control.
If you decide on an SET, I have a nice simple design I did earlier this year and posted on the DIY forums... PDFs for schematics (both 45 and 2A3) are available with a BOM.
Regards, KM
... just because you're paranoid, it doesn't mean they're not after you...
Old 9th November 2008, 05:59 PM   #6
Brit01 is offline Brit01  United Kingdom
Hi Richard,
I have the same problem but maybe even worse. I'm in Montevideo and trying to find any parts to build tube amps is mission impossible. Even such simple parts such as a good range of metal film resistors I end up banging my head against the wall.
I just got an Aikido 5687 kit and other parts from USA. My other half travelled and brought them back in her suitcase. The only way here.
also get some parts from UK by post. small packets otherwise customs kill you with charges.
I'm looking for a transformer builder now. Got some contacts but still planning what I need.
Good luck dude
Chris
Old 9th November 2008, 08:27 PM   #7
Default Re: What to build??
Will take a look.
Well, p2p will be an nice option, but im scared to do that, maybe creating an PCB will be the safest choice (never works with tubes yet)
Originally posted by Richard Ellis
Jose:
Dear Richard, i just want an simple design, I NEVER listen how an Tube Amp sound :S i just listen some Solid States that i build (kits), and some chipamps tha ti made myself. (and some crap yamaha amp that sound worst than my Chipamps amps
In Rosario i know 2 transformers factories, but really dont know how are the specs of the transformers that "we" need for tube amps.
i just used Toroidal ones and normal ones.
Regards, KM
Price Point less than 1000USD. I dont have some good speakers right now, i sold my B&W 602 s2 because i was run out of money., now i have some Full Range speakers that i made myself using FR125 and these are not very sensitives but im planning to build others soon.
Originally posted by Brit01
Hi Richard,
Good luck dude
Chris
if tell me some specs of the transformers i can ask here if is possible to build it.
Want to build tube amp jmillerdoc Tubes / Valves 6 6th March 2009 08:46 PM
1st Tube Amp - What to build? hifimaker Tubes / Valves 41 15th October 2008 02:33 AM
Help me build a tube TL? SamV Subwoofers 6 9th February 2008 01:43 AM
Looking to build a tube amp. Binaural Tubes / Valves 3 24th March 2006 04:18 PM
Copyright 1999-2017 diyAudio
