Old 7th November 2008, 03:24 AM   #1
Default Pete Millett Low-Mu Triode Preamp
Ok,
this one have driven me nuts, I have been having a hum problem I can't seem to resolve. I am seeing about 3 mv at the output and looking at the scope it would appear I have a high freq oscillation. I have tried (as per Pete's instruction ) isolated heater supplies, external power supply, changing grid resisters on the el34 to no avail.
here is a link to the build article http://www.pmillett.com/lowmu_preamp.htm . I built it pretty faithfully to the original (other than turning it 180 degrees ). I would think if it were oscillation moving my hand around the tubes would alter it but it does not. Anyone have any suggestions?
Bill
Old 8th November 2008, 04:47 AM   #2
Send a message via AIM to audiowize
Try plate stoppers?
Old 8th November 2008, 06:16 AM   #3
audiousername's Avatar
Where are R3, R5, R9 and R10 physically located?
Jason
Old 8th November 2008, 06:38 AM   #4
dsavitsk's Avatar
I tried to build a version of this a long time ago and could never get it quiet. I used lots of different 6080's and while they were all noisy in different ways, they were all too noisy to use. I eventually gave up on the project.
Old 8th November 2008, 11:39 AM   #5
SY's Avatar
My thought, too. They should be smack up against their respective grid pins.
If there's a sucker born every minute, where do the rest of them come from?
Old 8th November 2008, 04:02 PM   #6
They are tied to the pins, I have varied them up and down. If I wanted to eliminate the tubes and check the B+ what value resister would I substitute? I think the oscillation is in the EL34 current source but would like to confirm it. My trouble shooting skills are weak so this is a good learning opportunity.
for your help
Bill
Old 8th November 2008, 04:15 PM   #7
jan.didden's Avatar
Maybe a good moment to buy a simple oscilloscope?
Jan didden
/Yes! Its out: Linear Audio Vol 5!
I'm not an "accademic", just a plodder who loves a challenge - Ian Hegglun
Old 8th November 2008, 05:48 PM   #8
N1ESE is offline N1ESE  United States
Maybe a good time to re-read his first post where you'll see that he IS looking at it with a scope?
Old 8th November 2008, 05:57 PM   #9
Gordy is offline Gordy  United Kingdom
I suggest to start by ensuring that the power supply is functioning as required.
Disconnect the audio circuit and load the supply with resistors representing max load. Adjust supply as required to achieve target ripple. (Consider replacing choke with resistors as a short term measure).
Once you are happy with the supply then reconnect to the preamplifier circuit.
Focus on one amp channel only. Remove the vacuum tubes from the other channel. (Get one channel fixed then replicate the fix in the other channel).
Disconnect the load from the preamplifier (i.e. disconnect any power amp connected).
Step through the circuit one item at a time to identify at which point the fault is introduced.
I have seen a similar problem when there was inappropriate earthing arrangements; the preamplifer audio ground was connected directly to chassis ground which then connected to mains ground which then connected to the power amp chassis ground which then connected to the power amp audio ground which then connected back to the preamplifer ground via the 'ground' conductor of the un-balanced interconnection cable. The sum total was a big ground loop and lots of hummmmmmmmm...
Old 8th November 2008, 07:31 PM   #10
SY's Avatar
I, you want to check the CCS, disconnect the 6AS7s and sub in a dummy load resistor. In the original circuit, stage current is 50mA and the plate voltage on the 6AS7 is 125V. Using Ohm's Law, R = V/I = 125/50 =2k5. Power is P = IV = 0.05A x 125V = 6.25W. Use a 2.2-2.7k 10W resistor and see if the voltage across it is 50mA times the resistance.
Anyone Interested in Pete Millett Hybrid Amp PCB's? Geek Tubes / Valves 3 2nd November 2008 11:56 PM
Pete Millett's 829B amp -> monoblocks lochness Tubes / Valves 3 17th June 2008 12:30 AM
Last Pair of Pete Millett Universal Driver PCB's Geek Swap Meet 2 25th March 2008 09:03 PM
Pete Millett Universal Driver PCB's Geek Swap Meet 3 3rd September 2007 07:36 AM
Copyright ©1999-2013 diyAudio
