thyratron rectifier
thyratron rectifier
Old 6th November 2008, 07:27 AM   #1
sunrise is offline sunrise
sunrise's Avatar
Send a message via ICQ to sunrise
Default thyratron rectifier
can someone please explain me how to use a gas filled thyratron as a rectifier - and if possible with some schematics please......
thanks a lot for any effort....
i am a total idiot related thyratrons.....
when you burn it - burn it good
Old 6th November 2008, 08:05 AM   #2
Gluca is offline Gluca  Italy
Gluca's Avatar
I use them in "grid as plate" mode: the grids are to be connected to AC and the plates left alone (do not touch them... hi-volts are anyway present!). Pretty simple. You do need to cook them for 1 hour (fils on, AC off) before the first "ignition"; and 30secs - 1min when used daily. If they do not ignite or are prone to arc over just replace them (or try lowering the AC voltage in case of arcs).
Mind the max voltage! They can withstand lower AC this way. I use WE394As and they can go up to 300-350VAC grid-to-cathode. You need bigger thyratrons for higher voltages
Gianluca
Old 6th November 2008, 10:21 AM   #3
sunrise's Avatar
thanks.........
Old 6th November 2008, 01:44 PM   #4
Gluca's Avatar
Me! I Forgot! You want to use choke input filters ...
Ciao
Gianluca
Old 6th November 2008, 02:30 PM   #5
sunrise's Avatar
right - no problem with that
thnx
Old 6th November 2008, 03:05 PM   #6
JoshK is offline JoshK  Canada
What color do they glow?
Old 6th November 2008, 03:58 PM   #7
Gluca's Avatar
A blue glow (as all the mercury recfiers). The bird cage let the filament shine through. Lovely, isn't it? Some do not have the bird cage but a closed plate.
http://www.paolopoli.it/Audio/Bottom2008/img_1042.jpg
Old 6th November 2008, 04:02 PM   #8
Wow, those are beauts!
Somehow I was thinking Thyratrons were another type of gas, not mercury and glowed purple. Never experimented with this stuff before.
Old 6th November 2008, 04:46 PM   #9
kevinkr's Avatar
thyratron rectifier
Hi Gianluca,
How much current can you safely draw doing this and have you tried tying grid and plate together?
Just curious..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 6th November 2008, 07:47 PM   #10
sunrise's Avatar
thanks for asking this letter....
yes - mercury is glowing very, very nice.... heheheheh
thyratron rectifierHide this!Advertise here!
thyratron switching astouffer Tubes / Valves 6 14th November 2008 01:55 AM
Thyratron voltage regulation rcavictim Tubes / Valves 2 2nd March 2007 10:25 AM
thyratron? Burnedfingers Tubes / Valves 6 7th April 2006 01:54 AM
Thyratron Circuit imix500 Tubes / Valves 10 26th March 2004 05:46 PM
Thyratron heater supply? imix500 Tubes / Valves 8 16th March 2004 02:10 AM
Copyright ©1999-2017 diyAudio
