thyratron rectifier
thyratron rectifier
Old 8th November 2008, 07:58 PM   #31
Gluca is offline Gluca  Italy
Gluca's Avatar
OK, now we want to see pics
Old 8th November 2008, 08:54 PM   #32
sunrise is offline sunrise
sunrise's Avatar
Send a message via ICQ to sunrise
yes yes.... first i have to buy some thyratrons.....i will look for the 323 ones.....
:P
when you burn it - burn it good
Old 10th November 2008, 02:18 PM   #33
dave slagle is offline dave slagle  United States
:P
The 323's actually have a slightly lower PIV than even the 394.
dave
Old 10th November 2008, 03:16 PM   #34
JoshK is offline JoshK  Canada
Has anyone compared how these sound as rectifiers compared to other traditional HG rectifiers or damper diodes?
What sort of sound quality do they add?
Old 13th September 2015, 12:24 AM   #35
JBLman is offline JBLman  United States
Smile 394a wiring
Originally Posted by Gluca View Post
Ciao
I am using them in my 211 preamp. I believe I am drawing something around 50-60mA. Its a full bridge (thyratrons + solid state diodes) to get 500VDC out of a 300+300VAC transformers.
Thyratrons need many amperes for the filaments. If my memory doesn't fail, 394A filament runs at 3.5A. The bigger 355As and 354As a whopping 15A!
Gianluca
Can you show me how you wired these in a drawing? I'm interesting in using a set up like this also.
Old 13th September 2015, 07:50 PM   #36
Gluca's Avatar
mehh ... it was 7 years ago!!
I am traveling now, next week. sorry
Old 13th September 2015, 10:20 PM   #37
trobbins is offline trobbins  Australia
trobbins's Avatar
sunrise, did you just want to use the thyratron as a simple diode, or were you after phase regulated control of output voltage because of ????
Phase regulation is going to introduce additional higher frequency ripple harmonics that you then have to filter out - unless you are actually wanting to modulate your music with higher frequency mains related harmonics?
You may encounter gross reverse recovery inefficiency and disturbance if you were aiming for a capacitor input type filter circuit.
Old 13th September 2015, 11:59 PM   #38
No a problem!
thyratron rectifierHide this!Advertise here!
thyratron switching astouffer Tubes / Valves 6 14th November 2008 12:55 AM
Thyratron voltage regulation rcavictim Tubes / Valves 2 2nd March 2007 09:25 AM
thyratron? Burnedfingers Tubes / Valves 6 7th April 2006 12:54 AM
Thyratron Circuit imix500 Tubes / Valves 10 26th March 2004 04:46 PM
Thyratron heater supply? imix500 Tubes / Valves 8 16th March 2004 01:10 AM
