diyAudio Sponsor
Old 4th November 2008, 09:05 PM   #1
Send a message via MSN to audiodesign
Default Hi-end 845 with only two stage
yesterday evening I have started some measurement about 6HV5A used like 845 driver.
The schematic was very simple: inductance on anode, Rk = 100ohm, Ck = 470uF, Rg = 75Kohm and output capacitor 2.2uF on 33 or 100Kohm load.
With medium voltage operation (about 600V) these tubes give low sperformances because distortion is high 1.1% at 25Vrms.
The good result are obtain using 980V and 100ohm on catode to keep the power nead the 30w (35w is the maximun allowed), bias about 30mA.
With these value I have got the good 1% at 120Vrms on 33Kohm load.
The freq. response is limited to 50Hz(-3db) with 20H but it will be 10Hz(-3db) using 100H 50mA Sowter 8982.
The voltage amplification is 120/0.7=155x.
audiodesign has attached this image:
Click the thumbnail to see the original image.
File Type: jpg plot_980v_100ohm_470uf_20h_load_100k_ver2a.jpg (92.3 KB, 4970 views)
Old 4th November 2008, 09:06 PM   #2
Finally the first test result using 6HV5A to drive 845
6HV5A loaded by 20H (Rdc=70ohm) and Rk=100ohm Ck=220uF
950V 28mA
845 loades by Tango X-10S 10K/8ohm Vg=150v Rg=22Kohm
950V 100mA
10Vrms on 8ohm with 2% thd
Interstage 2.2uF // 0.33uF Audyn-Cap Plus
Very good sound
Very good voltage gain
Power can be increased using 1100V instead of 950v
Soon next test and photos
Old 4th November 2008, 09:07 PM   #3
Clio measurement
10Vrms on 8ohm
Old 4th November 2008, 09:38 PM   #4
The 20H inductance is only for this first test.
I am thinking to change this with LL1668/25mA
See actual frequency response
Old 4th November 2008, 09:40 PM   #5
the LL1668/25mA
have 100H so about 5Hz (3-db)
Andrea Ciuffoli
www.audiodesignguide.com
Old 4th November 2008, 10:01 PM   #6
test environment
Soon measurement with Lundahl AM output trasf. series
Old 5th November 2008, 02:41 AM   #7
N1ESE is offline N1ESE  United States
Good work so far, watching the development of this.
Old 5th November 2008, 08:24 AM   #8
This is the first schematic
Old 5th November 2008, 08:35 AM   #9
Gluca is offline Gluca  Italy
tarmac ripper
Gluca's Avatar
Andrea
did you try, or will you try, a grid choke for the 845? Things get usually better with them
Ciao
Gianluca
Old 5th November 2008, 08:39 AM   #10
Rob11966's Avatar
Hi Andrea,
I am right now in the process of building your 'New 845' with the EL34/845 combo.
This one looks a lot simpler. How does it compare? Can it be driven direct from a CD player
I am just about to finalise the power transformer order. Should I hold off? I would love to see a schematic of your power supply.
Rob
Aikido line stage - plus phono line stage cjkpkg Tubes / Valves 1 22nd November 2008 10:50 PM
Output stage biasing, with the driver stage andrew_whitham Tubes / Valves 0 19th May 2007 12:14 PM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 07:41 AM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 05:07 AM
Dsd without D/A stage.... kyrochan Digital Source 15 30th March 2005 05:36 PM
Page generated in 0.10730 seconds (78.38% PHP - 21.62% MySQL) with 11 queries
