| diyAudio Sponsor | ||
#21 |
Kevin,
Yes, with the 211 the voltage gain and swing since to be ok Using the 845: Ri=1700 u=5.3 with 11K5 (LL1620 con.B) we have Rout=1700/(38*38)=1.2ohm good to drive any loudspeakers to get 10Vrms on 8ohm (Pout=10*10/8=13w) you need Vg=10*38/5.3=72v Using the 211: Ri=3800 u=12 with 11K5 (LL1620 con.B) we have Rout=3800/(38*38)=2.6 too high to drive normal loudspeakers with 23K(LL9202 con.B) we have Rout=3800/(53*53)=1.35ohm to get 10Vrms on 8ohm (Pout=10*10/8=13w) you need Vg=10*53/12=44v but the 211 at 530Vrms on anode will be linear like the 845 at 380Vrms ? Probably it is true using the 211 and 23K transf. at higher plate voltage near 1200v With a 23K the bias current necessary is low so only 60mA will be enougth So is true that the 211 give less problem as input swing but it need higher power supply voltage to get same power and this mean more difficult to find good components with 1500Vdc like the capacitors. For a more precisious calculation add internal resistance of transformers (prim. and sec.). |
#22 |
Maybe this is a little far out, but why not make a Lundahl transformer coping with more current by adding an opposite current through the secondary? This to get rid of the capacitor and still get enough inductance. If 4:3,5 doesn´t give enough gain, one could go 3,5:4.
Brgds Lars |
#23 |
Using the 6HV5A is very difficult use interstage transformers because these need an inductance value about 100H and 25-30ma of dc current
#24 | |
www.kta-hifi.net |
#25 |
Paolo,
the 6HV5A have low microphonic effect if I tapping the bulb, I can hear a little tic on speaker but very low |
#26 |
I found the 6HV5A eats voltage and really starts singing over 1kV.
Blame the Manichaeists |
#27 |
Hi Andrea,
as I mentioned you, the best result I got is with 6H30, parallel ( are easy to select for similar sections), with a Tango NC20 interstage at 20 mA of Ia; the swing is 185 Vrms/530 Vpp ( at less than 2% of distortion. The Va is about 250 Vdc. I am close to the limit but the tube is really strong. Another tests http://www.multitask.it/845/1403-1Kh...15vin-nc20.jpg at this addres there is a FFt with 6BX7 and NC20 (another test) with 20mA at 1KHz, 3% THD; Vout about 130 vrms. at 20 hz the result is good. http://www.multitask.it/845/1403-1Khz-50mA-nc20.jpg at this link there is a FFT with the same setting but with 50mA of Ia; the 3% of THD is at 150 Vrm at 1KHz, but at 20 hz it is very bad. http://www.multitask.it/845/1403-1Kh...-5vin-nc20.jpg athis link is the same circuit with 20mA of Ia , 5 Vin, 40 Vout, 1 KHz; the IIIrd is low. Bye Walter |
#28 |
Oh very thanks Andrea, a precious information !
Cheers, Paolo |
#29 |
Walter,
6H30 or many other tubes have no enougth voltage gain to create a real two stages amp. You probably use the amp with a pre-ampl so this mean 3 stages. |
#30 |
Andrea,
if you use the Sowter 8540, 1:4; loaded with 50k you have 3K of input impedance; this will help. This means that with a G of 8 with 6H30 ( I have to check on my notes), with a Vin 2 volt (normally output for a preamp) we have 8 volt on input of 6H30 and 64 volt at the ouput of this stage. Bye Walter |
| Aikido line stage - plus phono line stage | cjkpkg | Tubes / Valves | 1 | 22nd November 2008 10:50 PM |
| Output stage biasing, with the driver stage | andrew_whitham | Tubes / Valves | 0 | 19th May 2007 12:14 PM |
| Should I replace Scott 222C phono stage with Claret phono stage? | Bing Yang | Analogue Source | 0 | 22nd August 2005 07:41 AM |
| Line stage preamp, based on SY's "Heretical Unity gain line stage" | Danko | Tubes / Valves | 23 | 18th July 2005 05:07 AM |
| Dsd without D/A stage.... | kyrochan | Digital Source | 15 | 30th March 2005 05:36 PM |
| Page generated in 0.11908 seconds (82.63% PHP - 17.37% MySQL) with 11 queries |
