diyAudio Sponsor
Old 11th January 2010, 04:54 PM   #221
Originally Posted by audiodesign View Post
Massimiliamo would like to know my last version of this amplifier.
I have decided to use the 6HV5A like driver loaded with the last Bartolucci 2:1 interstage transformer.
This combination give estreme performances as sound and measurements.
ok thanks for all!
Old 23rd January 2010, 06:03 PM   #222
Send a message via MSN to audiodesign
I am near the end with my 813 / GM70 amplifier
813 / GM70 amplifier with Bartolucci transformers
Old 15th February 2010, 10:24 AM   #223
I have opened a webpage about this project
845 Amplifier with only two stages
Now I am waiting the final version of 2:1 Bartolucci interstage transformers
Old 15th February 2010, 11:01 AM   #224
For the version 1 I cannot find other choice than this:
M-CAP® Supreme Silver / Gold & Oil 2.2uF 1200V dc
Old 19th March 2010, 08:50 PM   #225
I have received the last Bartolucci interstage.
Finished all the measurements on both the versions.
The version 2 have the same frequency band but give a better sound because does not use the interstage capacitor.
In both case the band is limited only by the output transformers.
Old 30th March 2010, 07:38 AM   #226
Now I am testing the vacuum tube diodes.
4 x GZ34 in diode bridge configuration.
Old 1st May 2010, 02:30 PM   #227
Finally arrived all the Bartolucci transformers to complete my 813/GM70 amp
Old 24th August 2011, 01:51 AM   #228
Default 2 stage GM70
Hello
Can I use these interstage transformer to drive my GM70 tube with D3A or with any other tube..
2 X SESCOM MI-13 INTERSTAGE TRANSFORMER | eBay
Unfortunately I can't afford to go with Tango interstage, I live on disability support unfortunately because I had car accident with bike.
I try to find some solution so I can put together my GM70.
Any help, comment welcome!
Greetings gabor
Old 24th August 2011, 01:56 AM   #229
rcavictim's Avatar
Originally Posted by gaborbela View Post
Hello
Greetings gabor
I think those would be worth trying if you have them, provided you aren't planning to run the GM70 in A2. With A1 you won't have to worry about DC current in the grid winding.
I.Q.Test. Have you ever purchased a recreational snowmobile?
Old 24th August 2011, 02:03 AM   #230
Hello
Thank you for your reply!
I do not have them but I can afford these or similar price interstage.
I want to be sure if I invest in them I can use them.
15K:15K a bit to high com pare to the 5K Andrea uses, I don't know.
I'll wait on more opinion. Or may be someone know better solution (what would feet better these amp)
Greetings gabor
Aikido line stage - plus phono line stage cjkpkg Tubes / Valves 1 22nd November 2008 10:50 PM
Output stage biasing, with the driver stage andrew_whitham Tubes / Valves 0 19th May 2007 12:14 PM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 07:41 AM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 05:07 AM
Dsd without D/A stage.... kyrochan Digital Source 15 30th March 2005 05:36 PM
Page generated in 0.12095 seconds (77.03% PHP - 22.97% MySQL) with 11 queries
