diyAudio Sponsor
Old 5th November 2008, 08:45 AM   #11
Send a message via MSN to audiodesign
The voltage gain is like my 845 amp.
http://www.audiodesignguide.com/New845/New845v2.html
http://www.audiodesignguide.com/New845/New845v3.html
so it can be driver directly by a phono-pre or any CD player
and it does not need a low impedance source like the amplifier with input transformers so it can be driven with normal sources.
Old 5th November 2008, 08:49 AM   #12
Rob11966's Avatar
Thanks Andrea,
So how does it sound compared to your "New 845" and if you could build only 1, which would you choose?
I also noted that you initially had problem with noise due to gain and then added the DC rectification - do you have the same issues with this one?
Rob
Old 5th November 2008, 10:12 AM   #13
This amplifier is in develop phase so some changes will be necessary to ear the final result.
In a first comparation test yesterady evening I like very much the sound of this new amp.
The my 845 amp. use Jensen copper film paper in oil interstage and this new two stage 845 use a MKP cap so a real comparation is not possible.
The my 845 amp. use Valve Art 845 and this new two stage use 845 Shuguang.
So a real comparation at this time is not possible but I will do this in the next weeks.
Old 5th November 2008, 11:36 AM   #14
About grid choke for the 845: never tested, to study
Old 5th November 2008, 04:54 PM   #15
Hi ,
Just for curiousity, is it this 6HV5A microphonic ? What happens if you
tapping the bulb, can you hear something from the speaker ?
Paolo
Old 5th November 2008, 05:05 PM   #16
kevinkr's Avatar
Interesting design Andrea, I'm working a two stage 211 based amplifier using the 5842/417A. Like yours also fixed bias and a 100H magnequest choke (exo-001) to load the 5842.. I have a pair of GE VT4C that will go in this amplifier.
Have not yet decided on the OPT..
Supplies per my usual practice will probably be regulated - might reconsider that if I end up using a parafeed configuration on the output stage.
www.kta-hifi.net
Old 5th November 2008, 05:08 PM   #17
In not normal use a 5842 to drive the 845 because the 5842 have too low voltage swing and too less voltage gain
Old 5th November 2008, 05:15 PM   #18
to increase the voltage gain you can use an interstage transf. 1:2 like the LL1660/10mA with primaries in parallel
In this case the D3A is teh best choice (see my measurements on http://www.audiodesignguide.com/PF2007/PF2007a.html)
The main problem using a 1:2 interstage transf. is the low output current.
I like very much the Lundahl with amorphous core as OPT.
Old 5th November 2008, 05:28 PM   #19
kevinkr's Avatar
Quite well aware of that, but I have 211/VT4C tubes in hand which have much higher mu (11) than the 845.. I was just commenting on the similarities, not suggesting you (or anyone to be clear) even consider the 5842 for this application.
I think even the D3A would be pretty marginal driving the 845, at least in triode connection even with a 1:2 step up IT.
I'll definitely check out what I can get the Lundahl amorphous core opt for in this country - it might be an excellent choice for my amplifier.
www.kta-hifi.net
Old 5th November 2008, 05:58 PM   #20
aroS3 is offline aroS3  Greece
Send a message via MSN to aroS3
Default D3a - Gm70 option 2stage option
Andrea, you have the irons, you have most of the circuit needs, why don't you try the promising D3a - Gm70 2stage SE solution, D3a can do the trick also with 1:1 interstage...
George
Aikido line stage - plus phono line stage cjkpkg Tubes / Valves 1 22nd November 2008 10:50 PM
Output stage biasing, with the driver stage andrew_whitham Tubes / Valves 0 19th May 2007 12:14 PM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 07:41 AM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 05:07 AM
Dsd without D/A stage.... kyrochan Digital Source 15 30th March 2005 05:36 PM
Page generated in 0.11133 seconds (78.43% PHP - 21.57% MySQL) with 11 queries
